Author Topic: Replacing Harmonic Balancer ?  (Read 1832 times)
Offline vpittman
« on: April 11, 2010 - 01:25:08 PM »
I'm in the process of pulling everything off the engine of my '73 Cuda, with a '76 360, replacing the fuel pump, water pump and generally sprucing things up.
Since I have everything off (engine is still in that car), how do I know if I should replace the harmonic balancer ? It is a '76 and I don't know it's been previously replaced...
If I should replace it, any opinions on which one should I get ? Don't want to spend too much unless it's really worth it, $200 - $250
I'm looking to make this a daily driver with a bit of performance
Thanks !
Re: Replacing Harmonic Balancer ?
« Reply #1 on: April 11, 2010 - 01:49:27 PM »
OEM harmonic balancers can be repaired if it's the rubber insulator needs replacing. Might be the cheapest route for you.
Harmonic Balancer
 Dale Manufacturing, 3425 Fairhaven Avenue N.E. , Salem, Oregon USA 97303
(503) 364-8685 PST www.dalemfg.com dalemfg@juno.com {07/05}
Harmonic Balancer
Damper Doctor, 1055 Parkview Ave., Redding, CA., 96001-3314. (877) 834-2137. DamperDoc@aol.com {04/03}
Harmonic Balancer
Winslow Manufacturing Company, 5700 Dean Avenue, Raleigh, N.C. 27604, 919 790 9713. Rebuilds Harmonic Balancers.
Offline dodge freak 2
« Reply #2 on: April 11, 2010 - 01:57:53 PM »
If the motor is running smooth and your not racing it I would just paint it.
If you get the motor rebuilt and balanced then get a nice new balancer and have the whole rotating  assembly balanced.
« Reply #3 on: April 11, 2010 - 10:55:50 PM »
 if you are just cruising with it & would just leave it on
Offline Aussie Challenger
« Reply #4 on: April 12, 2010 - 06:53:07 AM »
Check to see if it has slipped on the outer ring, if it has it might be easier to replace now, does the timing case seal leak, might be a good idea to replace especially if you are painting motor.   :2cents:
« Reply #5 on: April 12, 2010 - 11:38:04 AM »
if there is a groove where the seal rides on it you may want to replace it
