Author Topic: Cylinder head ID help..  (Read 970 times)
Offline challngd73
« on: April 11, 2010 - 03:36:34 PM »
I assume these are standard fare 346 heads, but when I look up part numbers, there are usually like 8 numbers or so for cylinder head casting numbers...didnt understand why there is only 4 in a row on these heads.  If my assumption is correct, these are most likely what came on my motor right? a 72 440..
thanks in advance.
Offline challngd73
Re: Cylinder head ID help..
« Reply #1 on: April 11, 2010 - 05:36:00 PM »
nobody?
« Reply #2 on: April 11, 2010 - 05:41:23 PM »
Turn them over, you will see the complete number. 346 came in 1971
Offline challngd73
« Reply #3 on: April 11, 2010 - 06:23:40 PM »
Id love to, but there is a heavy 440 attached to them;)  I just pulled my valvecover cuz I was curious what they were.  So, are they 346 heads?  Those are the only numbers I found on the head excpet the number 28 in  another spot.
« Reply #4 on: April 11, 2010 - 10:57:57 PM »
just a typical emiision open chamber head , nothing special or desirable about them
Offline challngd73
« Reply #5 on: April 11, 2010 - 11:20:25 PM »
Ok, I figured as much.  thanks Chryco.
