Author Topic: Put 318 or 383 in my cuda?  (Read 4271 times)
Offline djwhog
Re: Put 318 or 383 in my cuda?
« Reply #15 on: April 14, 2010 - 11:03:14 PM »
B motor and 727, also you nede to shorten drive shaft if the 318 is a 904 right?
Schumacher has mounts best easy way to go for the engine.
What differential is in the car? 8 1/4 or 8 3/4?
383s run strong it will be so much more fun to drive:)
Offline 72bluNblu
« Reply #16 on: April 14, 2010 - 11:27:14 PM »
I'm typically a small block guy, but given the two engines that you're choosing between I'd say go with the 383, sounds like a much better known quantity.
If you're running a 727 in the car now you shouldn't have to do any work to the driveshaft, but if you've got a 904 in the car now you'll have to change the driveshaft length too. I would upgrade the torsion bars at some point, and add sway bars if you don't already have them. But that's not something that you'd have to do at the same time as the swap.
Offline djwhog
« Reply #17 on: April 15, 2010 - 12:12:16 AM »
about 100lbs more weight is all..
Offline acudanut
« Reply #18 on: April 15, 2010 - 08:55:23 AM »
  You don't need those Schmacher mounts, unless it has a slant 6 K-frame.
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #19 on: April 15, 2010 - 09:11:46 AM »
Also need to change headers,radiator,carb linkage?,pulleys,brackets etc.318 would be a bolt in but obviuosly a 383 is a better choice if you want some power although a 318 will run decent with a a good 4 barrell setup.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline mopar12372
    • mopartech
« Reply #20 on: April 16, 2010 - 12:35:48 AM »
with all the work involved , its well worth the 383 if the money is there
RESTO PICTURES
« Reply #21 on: April 16, 2010 - 01:54:09 AM »
904 to 727 you need to shorten the driveshaft by 4"
 the slip yolk is different also
Offline acudanut
« Reply #22 on: April 20, 2010 - 12:17:02 AM »
No hard work here. Your Cuda will be more disireable too. :2cents:
