Author Topic: 3rd gear problem not fixed...  (Read 1742 times)
Offline QuartermileCuda
  • Shot of it in its Final Assembly
« on: April 12, 2010 - 09:36:32 AM »
This past weekend I dropped my 904 because 3rd gear seamed to be slipping as I would shift into 3rd. At full throttle I would shift into D and engine would Rev up then catch going back down in rpm and climb back up like normal. Now I am not a transmission person and have very basic knowlage of how these things work. The best guess that I had was that the Clutch packs were going bad.
So Saturday I pulled my pump and clutch packs out of the front and replaced all of the disks and seals. (forgive me if I am calling anytihng by the wrong name) I didnt touch anything below or behind that besides the filter.
Then Sunday I put my transmission back in and took it for a spin. Sadly the problem hasnt been fixed and thrid gear still has that same problem. Now my best guess would be something is sticking in the valve body? Anyone else have an Idea on what the problem could be?
71 340-6 AAR 'Cuda Concept.
(Was a 73 Barracuda)
69 Dodge Charger 383 4 speed. T5 Copper Needing Resto!
340/416 Stroker, 904 w/ Gearvendors gear splitter, 3:91 Posi.
Cant wait to see how fast she'll move. ;)
Offline tactransman
Re: 3rd gear problem not fixed...
« Reply #1 on: April 12, 2010 - 01:21:02 PM »
Do you have another VB you can try on it?
Terry-tactransman
Union, Mo.
« Reply #2 on: April 12, 2010 - 10:56:30 PM »
Whats a VB? lol sorry
Offline 6packCuda
« Reply #3 on: April 12, 2010 - 11:08:33 PM »
VB = Valve Body
« Reply #4 on: April 12, 2010 - 11:51:15 PM »
Not really. The only thing that I have that's close is parts from a Dakota Transmission back at home.
Offline dodge freak 2
« Reply #5 on: April 13, 2010 - 01:14:58 AM »
I would get a Turbo Action Cheetah VB :bigshades:
Offline tactransman
« Reply #6 on: April 13, 2010 - 11:33:47 AM »
Were the third gear clutches hurt at all?
Terry-tactransman
Union, Mo.
« Reply #7 on: April 13, 2010 - 06:32:43 PM »
From what I saw I don't think so. You could tell that some of the material had defiantly been taken off but there was enough there where it should have been functioning correctly. (At least I think so) I kept the old ones and I can get pics if anyone wants to see.
« Reply #8 on: April 13, 2010 - 08:34:29 PM »
I had a Friend of mine just take a look at what was going on with the transmission. I told him what I had replaced and the steps that I had taken to do it. And it looks like I have may of missed one... I forget witch set it was but I guess there was a piston at the bottom of one. So I never ended up doing that seal. My friend told me that if this was worn at all that this seal could cause the poor shifting into third. Think that this may be my problem?
Offline tactransman
« Reply #9 on: April 14, 2010 - 09:22:12 AM »
:grinyes:
Terry-tactransman
Union, Mo.
« Reply #10 on: April 14, 2010 - 11:18:56 AM »
Here are a couple I have on hand. I can get some close up ones of my used clutches tonight
Offline tactransman
« Reply #11 on: April 14, 2010 - 01:36:50 PM »
Those are smoked!
Did you check BOTH lip seals in that drum?
Is the bushing good.
Are the two sealing rings on the pump stator good and tight fit in the grooves??
What about end play?
Did you change any drums or pumps in the past on this trans?
Terry-tactransman
Union, Mo.
« Reply #12 on: April 14, 2010 - 07:00:23 PM »
Wow. lol I though those were just a little worn lol. The bushing was good and end play seemed alright. I dont think any of pumps or drums have been changed. So on a scale of one to ten. How bad is it?
Offline 6packCuda
« Reply #13 on: April 14, 2010 - 08:41:48 PM »
Dude, those suckers are toast. The steels tell the story. All those burn marks on the steels are from extreme heat caused by slipping. I'd say you need a total overhaul.
Offline tactransman
« Reply #14 on: April 15, 2010 - 09:35:13 AM »
Did you air check that drum on the pump when you had it apart?
Terry-tactransman
Union, Mo.
