dragging discs
Author Topic: dragging discs  (Read 612 times)
Offline Jim
dragging discs
« on: April 12, 2010 - 01:04:05 PM »
The manual front disc brakes on my Challenger seem to be dragging. I believe these are a Master Power conversion kit.
Had the front end up off the ground, and while I could turn the wheels, they won’t spin. There is definitely a lot of drag.
Pedal is coming up all the way, and I even shortened the rod a bit to see if it needed to come up further (it didn't)
What might be causing this issue? And how do I fix it?
-Jim
"Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. "
Re: dragging discs
« Reply #1 on: April 12, 2010 - 01:09:03 PM »
di you have a disc brake master cylinder on it ? the drum brake master has a 10 lb residual pressure valve inside it & could be causing the drag
Offline Jim
Re: dragging discs
« Reply #2 on: April 12, 2010 - 01:17:32 PM »
It's a disc MC
-Jim
Re: dragging discs
« Reply #3 on: April 12, 2010 - 01:20:06 PM »
contact Master power
 there has to be a residual pressure problem in the master or proportioning valve or the caliper is not retracting properly
« Last Edit: April 12, 2010 - 01:22:45 PM by Chryco Psycho »
Re: dragging discs
« Reply #4 on: April 12, 2010 - 05:18:59 PM »
 :iagree:   , if both wheels drag chances are pretty slim it's a caliper issue, Gotta be the wrong M/S .
