Author Topic: who makes a voltage gauge to replace amp gauge  (Read 21843 times)
Offline RB2929
Re: who makes a voltage gauge to replace amp gauge
« Reply #15 on: April 14, 2010 - 05:12:02 PM »
Hi ALL-
I received an email back from Redline:
Thanks for your inquiry.  Please give us a call at 661-259-8891 as it is a conversion rather than a part.
Shannon Hudson, Owner
Redline Gauge Works
I'll give them a call tomorrow (too busy today),
Ron
« Last Edit: April 14, 2010 - 06:21:32 PM by RB2929 »
Offline shadango
« Reply #16 on: April 14, 2010 - 06:16:59 PM »
Thanks for the awesome writeup UKCuda!
I think may stick my hand up there and see if I can reach the studs to check their fit.....When I was up under there before getting the car on the road to install the stereo, etc. I was impressed how clean and untouched it looked under there.....the backs of the gauges looked clean..no rust etc....
But worth checking for sure.
I will just watch it real close for now I think and address...like you said....once I get some other things done.  I dont want to have two open cans of worms at once...LOL
Offline UKcuda
  • Tell them I'm on my way
« Reply #17 on: April 14, 2010 - 06:44:22 PM »
No worries mate,
We have a saying (maybe common to the US I don't know) "Let sleeping dogs lay".  Anyway you can do that for now.
Just leave the ammeter alone until you have the other stuff done.  Then sort it out.  Hell it's been in there for 40 years - if it decides to go AWOL just now then that is basically an act of God and you can't plan for that.
'72 'cuda
Offline shadango
« Reply #18 on: April 15, 2010 - 04:38:20 AM »
Yeah, we have that saying too....another one is "If it ain't broke, don;t fix it."   :bigsmile:
Offline GoodysGotaCuda
« Reply #19 on: April 15, 2010 - 09:34:36 AM »
I waited until I had smoke pluming from behind my dash to bypass my amp gauge. I also installed a fire extinguisher  :22yikes:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline shadango
« Reply #20 on: April 15, 2010 - 10:43:28 AM »
 :22yikes:  Dont know that I want to go THAT long!  LOL
I read on the a-body forum that some guys just take one wire off the ammeter and connect it to the same post as the other.....instead of disconnecting both and bolting together.
Wondering if this would be easier to do for me, as my dash is still together....
Offline ShelbyDogg
« Reply #21 on: April 15, 2010 - 05:07:39 PM »
I would bolt both ends to each other with a screw and nut then put a big piece of heat shrink over it. The problem is that the stud shorts to the aluminum housing and smokes both wires. The fusible link can kill one side of the circuit but the alternator can self excite and keep frying the wires till it opens up. That means 3 legs of your wiring harness can melt from one short.
« Reply #22 on: April 15, 2010 - 05:09:10 PM »
I didn't, but mine 'looked fine' until then.  :dunno:
1976 Dodge Warlock
Offline RB2929
« Reply #23 on: April 16, 2010 - 11:09:28 AM »
Hi All-
I fianally had a chance to call Redline (661-259-8891).  Very nice people.
Basic process for Amp to Volt meter;
- Remove your Amp meter and send it, along with the pot metal housing to Red Line.
- They replace the meter with a new VDO Volt meter
- They modify the hosing to accomadate the new meter
- they rewire the whole assembly, and send it back to you
-- Cost is $140 +shipping
Not a bad deal
Ron
Offline ragtopdodge
« Reply #24 on: April 16, 2010 - 04:19:02 PM »
Hi All-
Not a bad deal
Ron
Does it sweetp LEFT to RIGHT?
DOes that include changing the silk screen of both the gauge face and the clear bezel-holding FUEL-TEMP-OIL-VOLT gauge cover?
Is that for both Rallye and non-Rallye types?
I think it'd be worth first trying the cheapo Sun gauge retrofit and if it works, just send the aforementioned silk screen faces to redo.
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
« Reply #25 on: April 16, 2010 - 04:26:27 PM »
Often happens like that with electrical stuff.
They look to be in perfect order........until they're not.
« Reply #26 on: April 16, 2010 - 06:42:00 PM »
If anyone has pictures of this conversion with non rally gauges please post a picture?
I'm in for a group buy if it happens?
Offline ShelbyDogg
« Reply #27 on: April 16, 2010 - 07:57:52 PM »
Brad. for a standard guage cluster, I would use rt-eng.coms unit. It uses a spare Temp or gas guage.
 http://www.rt-eng.com/mediawiki/images/f/f6/Stealth_Voltmeter.pdf
Right now I'm looking for a spare rally gas guage to convert my rallye cluster.  I can change the lettering with rub on stencils.
Offline wally426ci
    • maryland mopars
« Reply #28 on: April 17, 2010 - 09:12:20 AM »
I am pretty sure they will do this @ Carlisle for you if you bring it. I saw them last year and inquired about fixing my tach.  :wave:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #29 on: April 17, 2010 - 11:20:31 AM »
Hummm thats a good idea! So All I need is a spare temp or gas gauge? :ebay:
