Author Topic: Any Experience With a Stainless Steel Brake Booster and Master?  (Read 791 times)
Offline ghjedi
Hello,
I've been replacing all of my old braking system components and am left now with just the booster and master cylinder to replace for my 1972 Challenger.  I have power front disc brakes and rear drums.
I'm thinking about going with a Stainless Steel combo I found and am curious if anyone has had good (or bad) experiences with this one?
http://www.summitracing.com/parts/SSB-A28144/
1 of 1 1972 Challenger 440 4sp Convertible Blue GB2
2012 Challenger R/T Classic Blue Streak Pearlcoat
Re: Any Experience With a Stainless Steel Brake Booster and Master?
« Reply #1 on: April 15, 2010 - 01:34:22 PM »
Never tried one but the design is using a GM master if that matters
 I would be more inclined to use the Later Dodge truck 2 bolt Alum master
Offline ghjedi
« Reply #2 on: April 15, 2010 - 03:13:45 PM »
Thanks Chryco.  Do you have any suggestions on a part # or supplier?  This is the only 1 that Summit carried and I'm worried about a good fit, if it's using a GM master.
« Reply #3 on: April 15, 2010 - 03:32:38 PM »
this is more difficult as you would need a 2 bolt booster , I have a local rebuilder here that can help but not sure what might be available to you , the master is easily obtained through any local parts store from a rebuilder like Cardone
Offline ghjedi
« Reply #4 on: April 15, 2010 - 04:37:16 PM »
That's good to know.  I was thinking about replacing both my booster and master at the same time and buying them together with something close to the orginal equipment to ensure the best fit.
