Author Topic: 440 Source Billet Distributer  (Read 688 times)
Offline outlawse
« on: April 16, 2010 - 09:15:46 AM »
Guys:
I recently installed a 440 Source billet distributer in my 440.  I removed the old vac unit.
Does anyone know what type of advance the 440 Source piece is calibrated too ?
How much advance ????  What rpm ???
Thanks...
1972 Dodge Challenger
1970 446 RB: Six-Pack cam, M1 Dual plane Intake, Hooker Headers, much more...
Turbo Action 727: 3400 Stall, Manual Cheetah Valve Body - 3.91 Gears
On bench:  Performer RPM Intake, 509 114 LSA Cam, 440 Source Heads
Offline TROUBLE987
Re: 440 Source Billet Distributer
« Reply #1 on: April 16, 2010 - 10:27:26 PM »
They have a mechanical advance curve built into them, which is easily adjustable.I would set the timing low start it up and bring the rpms up with a timing light on it to see..set the timing at 28 degrees then bring the rpms up and see how far it advance,it should be total out about say 2500-2800 you will be able to see it with the light,if you bring it up to 3000 rpms and its not moving anymore see where you are if its setting at 34 degrees at 3000 and not moving then you a 6 degree mechanical advance..if your just using it for drag racing then pull the dist. and weld it up and be done cause you dont need it advance on the drag strip..hope i helped
Offline outlawse
« Reply #2 on: April 19, 2010 - 06:44:53 AM »
I set the idle advance to +18.
I will bring the car up to 3000 rpm and check the timing.  I am aiming for +39 total.
The dizzy should be full advanced by 3000 right ?????
« Reply #3 on: April 19, 2010 - 10:40:54 AM »
sounds right , I have not seen the 440 Source dist so I don`t know what is adjustabe or what they are set with foir advance & he was not at MATS this year
Offline TROUBLE987
« Reply #4 on: April 19, 2010 - 03:04:09 PM »
Yea it should be fully advance by then..sounds like your going about the right way!!
