Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
727 and 904
« previous
next »
Print
Pages: [
1
2
Author
Topic: 727 and 904 (Read 6356 times)
rnsykes
Jr. Member
727 and 904
on:
October 06, 2004 - 11:34:01 AM »
What years will interchange with my 71? I've been trying to locate a rebuildable 727 at the local salvage yards, and it seems that nobody will help me because they dont have any 71 laying around. I'd like to know for sure before I start asking them about different years.
Logged
DodgeFreak
Sr. Member
Cars and trucks are my friends..
Re: 727 and 904
Reply #1 on:
October 06, 2004 - 11:54:40 AM »
what engine?? theres a difference between bigblock and small block but i think the tail shafts are the same on alot of them??? enless your wanting to keep it date coded alot of years will work..you could even use a 518 od trans.
Logged
74 Plymouth Duster- restoring
77 Dodge D150 shortbox- as long as i don't change my mind will be a step side dually diesel or a 383 powered truck
04 durango 4.7
rnsykes
Jr. Member
Re: 727 and 904
Reply #2 on:
October 06, 2004 - 12:25:52 PM »
NO, it's gong onto a 340. I'm not interested in keeping it date correct either, but the 518s I have found are about double in price. Is the overall length the same on the 904's and the 727's? When I do make the switch will my driveshaft work still?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: 727 and 904
Reply #3 on:
October 06, 2004 - 01:21:16 PM »
Which tranny do you have now ?
The 904 & 727 use dufferent slip yolks & are a different length
probably the easiest source for a 727 is a truck or van
Logged
rnsykes
Jr. Member
Re: 727 and 904
Reply #4 on:
October 06, 2004 - 01:44:37 PM »
Right now, I'm using the 904 that was behind the 318 that used to be in the car. It seems to be working fine, but from what I hear the 904 won't last. What year truck or van should I be looking for, and what other mods will I have to make?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: 727 and 904
Reply #5 on:
October 07, 2004 - 01:01:03 AM »
any 360 truck up to mid to late 80s will have the 727 small block tranny , take the driveshaft so you have the correct slip yolk
Logged
Bart
Full Member
Re: 727 and 904
Reply #6 on:
October 07, 2004 - 04:09:53 PM »
E-bay 7926779273
7926691587
7926163875
Logged
1970 Cuda 383
2008 Titan
2010 G37s
1996 Advantage Victory 27 502ci
2013 HD Roadking
neifvneiurv
Jr. Member
Re: 727 and 904
Reply #7 on:
October 21, 2004 - 10:46:46 AM »
Sykes, try this link, it has more information than you will probably ever want to know about the Torqueflites. Btw, the two cases are very different in size, therefore requiring a different cross member and driveshaft.
http://www.allpar.com/mopar/torqueflite.html
Kevin
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: 727 and 904
Reply #8 on:
October 21, 2004 - 01:26:32 PM »
the crossmember stays the same
Logged
neifvneiurv
Jr. Member
Re: 727 and 904
Reply #9 on:
October 21, 2004 - 06:43:22 PM »
You're right Chryco, I realized that after I posted it. I've been trying to find out some info. for Sykes about the shifter linkage and kickdown. I'm not certain they are interchangeable either. Do you know? I would like to know too, for futures.
Kevin
Logged
rnsykes
Jr. Member
Re: 727 and 904
Reply #10 on:
October 22, 2004 - 08:57:02 AM »
Thanks for all the info so far guys. It looks like I'm going to be trying to gather some parts over the winter. I don't do much work on the car during those months becasue my garage is barely bigenough for the car itself. Put it this way, Once I'm i nthe garage, the doors barely open.
Logged
neifvneiurv
Jr. Member
Re: 727 and 904
Reply #11 on:
October 22, 2004 - 12:41:33 PM »
No problem Sykes, that's what the boards are for.
I know for a fact that the torque converters and driveshafts are not interchangeable. I don't know for certain that these other items are not interchangeable, but I am just mentioning them as things to consider when gathering your parts for the swap....those items are: bellhousing, shifter linkage, kickdown linkage, yoke, and throttle pressure adjust.
Kevin
Logged
DodgeFreak
Sr. Member
Re: 727 and 904
Reply #12 on:
October 22, 2004 - 05:04:49 PM »
the bell housings you can't change anywaysbut a 360 727 will fit any small block. you might be able to get the shifter linkage to work if you tweak it. i've never done a swap like that...where are you located i might be able to pick you up a 518 pretty cheap.
Logged
04 durango 4.7
rnsykes
Jr. Member
Re: 727 and 904
Reply #13 on:
October 23, 2004 - 09:27:45 AM »
I'm in south Jersey. I looked around on ebay, but the 518's are more than I want to spend. The Junkyards around cant grasp the concept that some parts are interchangable.
Logged
DodgeFreak
Sr. Member
Re: 727 and 904
Reply #14 on:
October 23, 2004 - 04:07:38 PM »
how much was ebay wanting i could probably pick you up a 518 for around 200-300 bucks...but it would cost to ship..
Logged
04 durango 4.7
Print
Pages: [
1
2
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
727 and 904
