Author Topic: 360 out of a ramcharger  (Read 802 times)
Offline Scat Pack Fever
  • Mopars Rule!!!!!!!! Always Have, Always Will
  • Chrysler did it best!
« on: April 16, 2010 - 07:55:12 PM »
Hello! I just purchased a 360 out of a 1984 ramcharger. I am going to put it in my challenger. I know I have to change the oil pan and the sump pump, but what changes will I have to make so it will work with my 318 motor mounts from the original engine?
Offline ntstlgl1970
  • T a c o c a t
Re: 360 out of a ramcharger
« Reply #1 on: April 17, 2010 - 02:17:00 AM »
Since it's a pre magnum engine it should bolt right in place of the 318. The balance on the torque converter or flywheel may be different if you are using the ones that came with your car
« Reply #2 on: April 17, 2010 - 04:11:41 AM »
the left engine mount is different on the 340/360 from the 318
« Reply #3 on: April 17, 2010 - 07:55:28 AM »
Can I adjust the left mount to make it work?
Offline dodge freak 2
« Reply #4 on: April 17, 2010 - 09:05:59 AM »
I believe you can--needs to be shimmed up on one side..
 :useless:
Offline ntstlgl1970
  • T a c o c a t
« Reply #5 on: April 17, 2010 - 11:49:41 AM »
CP - is it the block to mount adapter that's different between the two? I did not know that.
Offline moper
« Reply #6 on: April 17, 2010 - 02:45:02 PM »
The difference in the brackets are small. They can be used with shimming (washers) with a little effort.
« Reply #7 on: April 17, 2010 - 06:58:52 PM »
it is the block adapter to the mount that is different
