73 chally small blk car...stock tank....mech pump.....451 stroker with a mid to high 5'ish lift roller (cam motion grind) cant remember the exacts on the cam, written down at home,....diamond 10.5 to 1 slugs, mopar perf crank, comp roller rocker set up at 1.5, on ported and polished 452 steelies, that flow 285.....m1 intake single plane, 850 quick fuel, 6al msd, billet mopar perf, dizzy set up by F.B.O,.....727 reverse valve body , cohen 3200 stall, built by abbruzio racing trannys, 8 3/4. 391 gears.....thats about it...have any idea what this car "should run" in the 1/4 on 10.5 rubber?...super stock springs with adj snubber too....thanks
