I've dreamed on this a bit but could not find info,
I couldn't find anything either, the only thing I found out that I didn't already know is that this design of ammeter is also used in the De Tomaso Panteras (gauges made by Veglia). It seems the Pantera chaps are keen to change to voltmeters as well, but they do it by swapping out the whole gauge.
It just came into my head yesterday morning that maybe I could add a coil to make the guage move and I remembered I had that little relay lying around in my electrical junk.
When I found that the coil easily moved the gauge I knew it had to be do-able.
The thing with the fridge magnets was just lucky (I guess maybe you say "refrigerator") - I needed something small and strong. First I went off to my daughter's room because I knew she had some magnetic earrings, but she had thrown them away (do'h !) so I was pacing round the kitchen thinking "magnets, magnets, magnets" and suddenly I saw all the dumb stuff stuck on the fridge door - eureka!
In the end I used the two little magnets stacked up one on the other (not like in my photo) - that gave a strong enough field to pull the pointer right off the end of the gauge, then I glued a little rubber stop in the back so it didn't go more than the end of the markings. Theres an aluminium quadrant on the back end of the pointer round where the axle pin is and it was easy to glue the little stop on the brass conductor so it blocks the quadrant from rotating any further.
With the magnets like that I cranked up the coil (lower resitor value) to neutralise the stronger field and get the pointer back to center - that gave it more movement per volt across the scale.
One funny thing I noticed was that holding the gauge face up and turning it around the pointer was moving slightly, I guess due to the earth's magnetic field.
When I get time to fit it in the dash we shall see how stable it is in service - I think it will be OK.
I think getting it to work right depends a lot on what coil and magnets you have to play with. I wouldn't recommend it for everyone, but it's good fun if you are a bit mental and enjoy goofy projects
like me.
