Author Topic: A/C heater fan not blowing  (Read 1066 times)
Offline 500Stroker
« on: April 18, 2010 - 12:37:04 PM »
1973 Challenger, factory A/C car.
My fan blower has been intermittant for the last year.  When it would not work I would push all the buttons and move the high low switch back and forth a few times and eventually it would work.  Now I get nothing.  I pulled the plug off the back of the puch button switch.  I do have power in the center pin of the three wire connector.
Connected 12 volts directly to the fan and it does work.
Is there anything inside the switch that can be rebuilt/repaired or should I just look for a new one?  I did not take it out of the dash yet.
Offline CHL2T
  • Handle it, man!
Re: A/C heater fan not blowing
« Reply #1 on: April 18, 2010 - 01:45:30 PM »
Slotts can hook you up, gonna have him rebuild my switches and stuff if I ever get around to it :smilielol:
« Reply #2 on: April 18, 2010 - 08:00:38 PM »
Dunno about A/C but my standard heater fan switch was intermittent... I bent back the tabs that hold it together, dissembled cleaned, lubed & reassembled ..works fine now.
Offline ShelbyDogg
« Reply #3 on: April 20, 2010 - 12:32:46 AM »
look on page 2 of this thread. I drew a diagram of the A/C fan circuit. You probably have a dirty push button switch that can be taken apart and scraped with a razor blade.
http://www.cuda-challenger.com/cc/index.php?topic=65095.15
Offline 500Stroker
« Reply #4 on: April 20, 2010 - 08:26:42 AM »
Thanks,  I'll disasemble the switch and give it a good scraping tonight.
