Something else,
You can go to Advance Auto and pick up a window trim removal tool. It will be located in their tool/special tools section. It has a handle with a flat piece of steel that slides under the window trim and grabs ahold of the clips that hold the trim on. You pry back a little and the trim should release. The tool is about $10 or so.
A word of caution....take your time make sure you are engaging the trim clip and not the edge of the window. If you grab the edge of the window you risk cracking it. BELIEVE ME I DID IT!!!!
PS - Call the auto store first and ask them. If needed I will find mine, take a pic and post it for you.
T1971Chally
