Here is what I was facing--
Took out all the spark plugs.....Neither rag would budge as we turned the motor over by hand.....
Pulled the intake off and one rag was only in the plenum and came right out...the first picture.....it was on its way into #6
The other rag (the second photo) was the problem child.
Let me first say I have an angel of a wife.
she layed across the motor, holding a jar in one hand to catch the gas comingfrom the fuel line and tugging the rag in the other hand while I crawled under the car to turn the crank by hand.
slowly but surely....
And then, one last turn...
There is signifigant stretching to the rag, but it seems that a little is missing....I dont know if some of it could have been burnt or what...with a rag coming thru the intake for that cylinder, cant see how any fuel could have gotten thru.....
I layed across the motor and peered into the cavity and can still see some rag burnt to the backside of the intake valve.....got as much as I could out with a flexible grabber gizmo....cant see anything now in the spark plug hole.
The motor seems to turn fine, the rockers go up and down and don't look broken or bent....the rods all seem to be fine, checking them by spinning them in place.....
What else should I check? Do you guys think I can get by without pulling the head seeing as we got what we got out or would pulling the head be mandatory? And if I remove one I guess I would need to do both so as to make sure the head gaskets I use match right?
I have no way of knowing how much rag was in the chamber...just saw a little thru the spark plug hole....could I have jammed up a rod/piston?
That loud rapping was very scary....I guess it was because the one edge of the rag had been sucked into the combustion chamber and was preventing the valve from closing. and the rocker was just slapping on there?? Or maybe it was low end...I dont know.
Could I have spun a bearing or something from this assinine mistake?
What else can I check for?
And if you think I can try putting her back together, I assume an oil change will be due since some antifreeze gets into the valley when you pull the intake....but anything else?
In theory, since it was a soft shop rag, would the remaining fibers on the backside and whatever may still be in the chamber just burn off? The missing piece of the wrag looks more chewed up than ripped off, if that makes sense.
I am kicking myself so hard over this.
How stupid.
i could have had her on the road tonight...instead she is in pieces becasue of a stupid, amateur mistake I made.
The ironic part is that I put the rags in there while I was working to PREVENT something getting into the engine.
Ifele like such a dumb@ss.
so, tell me what you would do at this point.
Thanks guys.
On the upside of this (if you can call it that), I think I now know I have a "purple cam".......the front end of the cam is very purple.
And to my wife -- I couldnt have married a better mate.
