Author Topic: Broken rear wheel bearing  (Read 786 times)
Offline cudadude013
    • Friday at the Lake
« on: April 21, 2010 - 05:39:28 PM »
I have a broken rear wheel bearing on the passenger side of my '72.
Is this something I can fix with some standard tools at my house or will I need to take it into a shop?
I can buy all the parts necessary at my local auto parts shop but they had no idea how difficult it would be to swap out.
Any input?
Thanks guys!
« Last Edit: April 21, 2010 - 06:41:04 PM by cudadude013 »
Offline cudadude013
Re: Broken rear wheel bearing
« Reply #1 on: April 21, 2010 - 07:05:51 PM »
I did some more looking around and was able to answer my own question. It looks like I would need a press to install the bearing. I really prefer to do my own work but sometimes I just don't have the necessary tools.
Thanks
Offline GoodysGotaCuda
« Reply #2 on: April 21, 2010 - 07:44:58 PM »
I'd recommend at least just pulling the axles and taking them into somone to pop the new bearings on. I'm the same way when it comes to my vehicles.
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #3 on: April 21, 2010 - 08:56:08 PM »
The bearing itself slides on and off easy enough. The lock retainer is the piece that is pressed.  I cut my retainer off with a die grinder almost all the way through, then, I use a chisel and crack it in half.  I have a press now, but back in the mid 80's I didnt. I used a thick 2.5 inch pipe that was cut off square and just slipped it over the axle and hammered the retainer on by sliding the pipe up and down. I never had a problem. I dont recomend cutting the retainer off with a torch. Some do it, but you could cut the axle easy or get it to hot and it could get brittle on you.
Offline Aussie Challenger
« Reply #4 on: April 21, 2010 - 10:25:20 PM »
Also before using the pipe like a slide hammer fit the old lock ring and hammer on that to protect the bearing and the new lock ring.   :working:
