Author Topic: Looking for advise. Lucas gear oil? Valvoline vr1 oil?  (Read 1449 times)
Offline sparkybr74mr
« on: April 21, 2010 - 10:46:14 PM »
I just had my transmission rebuilt  and was wondering if the Lucas gear oil 80-90w is a good product. I also heard Valvoline VR1 10-30w is a good oil to use also for my engine that has been rebuilt and now has about 1k miles. Any help or advise is apreciated. What about synthetics also? I have a 440 mag stock build, and 833 tranny. Summer in S.W. NM reaches around 110 at times.
« Last Edit: April 21, 2010 - 10:48:00 PM by sparkybr74mr »
Offline 'Cuda Hunter
  • Tastes Like Chicken
Re: Looking for advise. Lucas gear oil? Valvoline vr1 oil?
« Reply #1 on: April 21, 2010 - 11:27:02 PM »
Just as a note, the lucas oil additive, when put into freezing weather and left to sit for a while, then started and turned in the little display, foamed like mad.  Worst looking crap I have ever considered putting into my engine.
Of course, you might not ever have freezing weather but thought it worth the note.
« Reply #2 on: April 22, 2010 - 01:25:56 AM »
I would use a non syn 80-90 gear oil in the trans
the engine is tough , there really is no good oil to recommmend for flat tappet cams anymore & EOS additive has been discoed too
The New Z-Alt oil or Brad Penn or similar oil designed for older flat tappet cam engines is what you need , I would not use synthetics until you have 4000 mile on the engine to make sure it is properly seated in & you still need an additive with synthetic oils as the Zddp & Scuff lube has been removed
Offline barracuda7199
  • needs a resto but having to much fun right now
« Reply #3 on: April 22, 2010 - 09:22:55 AM »
hughes engines makes some good oil additive for flat tappets. http://www.hughesengines.com/Index/products.php?browse=category&level0=T2lsICYgQ2hlbWljYWxz&level1=QWRkaXRpdmVz they also sell some good oil
Brandon
71 Barracuda 440 727
(O O {]{]{]|[}[}[} O O)
