Author Topic: 6-Pak Diaphragm Spring Kit  (Read 1128 times)
Offline cwestra
« on: April 22, 2010 - 09:38:25 PM »
Summit sells several diaphragm spring kits, but none that specifically call out the 2300 series Holley carbs on the 6-Pak set-up.  Does anyone know if any of these kits will work for the 2300's?  And if so, would I need to complete kits?  All I am looking for are the lighter yellow springs.
Also, who sells the clear sight bowl plugs?
Corey - in Northern Indiana
Offline 6packCuda
Re: 6-Pak Diaphragm Spring Kit
« Reply #1 on: April 22, 2010 - 10:16:58 PM »
The six pack carbs use the same diaphragms and springs as the regular Holley 4 barrel carbs. And yes, you have to buy two kits. :2thumbs:
Offline Jim
« Reply #2 on: April 23, 2010 - 08:09:18 AM »
Not true.
Same springs, different diaphragms. "Yellow" is the stock spring.
Sight bowl plugs can be had through Summit (and other sources) as well. I recommend using these while setting the float level, then swapping back to the regular plugs. The clear plastic plugs get brittle over time and have been known to leak.
-Jim
"Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. "
Offline cwestra
« Reply #3 on: April 23, 2010 - 09:34:40 AM »
Not true.
Thanks.  My springs are old and not painted.  Is there a way to determine which spring it is (number of coils, diameter of wire, etc...)?
Offline Jim
« Reply #4 on: April 23, 2010 - 01:34:31 PM »
Not really. If you had a set to compare with, you might. The wire gage and coil count varies, so it's hard to tell the difference.
-Jim
Offline 500Stroker
« Reply #5 on: April 24, 2010 - 12:35:59 PM »
I bought holley spring kits # 20-13 for mine.  The instructions say the plain spring is the standard spring.  I just swapped in the short yellows to open the outboards earlier.
Offline cwestra
« Reply #6 on: April 24, 2010 - 12:52:09 PM »
Thanks.  I guess I'll order a couple of those kits.
