Author Topic: pitman arm removal  (Read 721 times)
Offline barryv
pitman arm removal
« on: April 24, 2010 - 09:26:44 PM »
hi, what would be the easiest way to remove pitman arm on my 72 cuda,thanks
Offline FJ5_440
  • Wisconsin
Re: pitman arm removal
« Reply #1 on: April 24, 2010 - 09:59:49 PM »
Buy, Rent, or Borrow a pitman arm puller and a tie rod end puller (or pickle fork).  It turns it into a five minute job.
** Shane **
Offline barryv
« Reply #2 on: April 24, 2010 - 10:29:21 PM »
thanks
Offline bordin34
« Reply #3 on: April 25, 2010 - 02:01:20 PM »
Advance auto parts loans the tool for free, just put down a deposit. The hardest part of it is finding a socket big enough, I used vice grips. Also when you put the new one on make sure you line it up right, it should only fit on one way you do not need to force it.
1973 Charger SE Brougham Black 400 auto
1974 Charger SE Brougham Blue 318 auto-SOLD
Offline Katfish
  • 70 Challenger
« Reply #4 on: April 25, 2010 - 02:17:32 PM »
Harbor Freight has the puller for around $5
Get a long pipe to put on your rachet for leverage.
