Author Topic: 8 3/4 rear ends - Is there a difference??  (Read 1530 times)
Offline kmyles
« on: April 26, 2010 - 04:58:13 PM »
There must me different versions for the 8 3/4 rear diff. The one I just bought has and open side case and only has two spider gears..one on either side. I though they were all the same. I guess mine is from and older gereration..not as good????  :clueless:One more thing the pin that goes through the housing to hole the two spider gears is missing.  :banghead: :pullinghair:Anyone know where I can get one??? :dunno:
_________
Kevin
Mopar Lover....Cuda's....Challengers Rule!!!!
- 1951 Dodge - 2 door hardtop (Sold!!)
- 1971 Dodge Challenger
- 2012 Dodge Challenger Yellowjacket
Hard to believe what 20 years will do!!!!
Re: 8 3/4 rear ends - Is there a difference??
« Reply #1 on: April 26, 2010 - 05:06:45 PM »
Sounds like you got a single track. Also the pin will have 2 spider gears with it to. It takes 4 gears
Offline kmyles
« Reply #2 on: April 26, 2010 - 06:43:48 PM »
Do you know where I might get the pin and gears???
_________
Kevin
« Reply #3 on: April 26, 2010 - 06:47:14 PM »
If my friend dint haul it off, I gave him a perfect center last month. It is good enough to run as is. Or take what you need off of it. I will ask him tomorrow for you. I will see if I got an open center some where if not and see about sending the parts to you. I got an MRI to do tomorrow first tho.  Are you in Canada?  I forget
Offline kmyles
« Reply #4 on: April 26, 2010 - 07:00:47 PM »
Yep in Canada. I'll be in PA/WV for the next 10 days if that helps??
_________
Kevin
« Reply #5 on: April 26, 2010 - 07:08:03 PM »
I will try to get this stuff goin and find out by wednesday for you
Offline kmyles
« Reply #6 on: April 26, 2010 - 07:34:46 PM »
Thanks Al. It's appreciated!!!
_________
Kevin
Offline kmyles
« Reply #7 on: April 26, 2010 - 08:27:19 PM »
So is a single track not as good?? What's the difference?
_________
Kevin
« Reply #8 on: April 26, 2010 - 08:35:17 PM »
only one wheel traction.  Not hp.
Offline kmyles
« Reply #9 on: April 26, 2010 - 08:45:04 PM »
I was told it was a SG. It has the clutches in it. I already have the peg leg in the car now! I'm confused???
_________
Kevin
« Reply #10 on: April 27, 2010 - 12:17:30 PM »
the cone type has 2 gears on the cross pin  & 2 axle gears & has springs between the axle gears , so I assume you are missing the cross pin & 2 gears ?
the clutch type has 4 gears on the cross pin & is twice as strong
« Reply #11 on: April 27, 2010 - 06:27:49 PM »
I thought I read your post to say that it was open and missing a pin and 2 gears. You didnt mention springs n stuff.  I checked today and my friend scrapped the open case
« Reply #12 on: April 27, 2010 - 06:32:37 PM »
the pin & gears are different between the open & cone type carrier & do not interchange
Offline kmyles
« Reply #13 on: April 27, 2010 - 08:24:48 PM »
this has clutchs in it??
_________
Kevin
« Reply #14 on: April 27, 2010 - 08:29:40 PM »
post a pic
