Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
dash parts install sequence
« previous
next »
Print
Pages: [
1
Author
Topic: dash parts install sequence (Read 1133 times)
e-chal
Jr. Member
on:
April 26, 2010 - 05:50:46 PM »
what is the install order of all the dash parts? The dash frame is out of the car and I have a new dashpad to install. In particular, in the assembly sequence, when does the dashpad get installed? This is a 1971 Challenger, non-Ralley dash, with A/C cutouts which will not be used as A/C-heater box is removed but will have the A/C dash vents installed and single center speaker. How much can be preinstalled in the dash before putting dash back in the car? Thanks for any help on this.
Logged
Moparal
Permanent Resident
Re: dash parts install sequence
Reply #1 on:
April 26, 2010 - 06:13:06 PM »
Assemble the complete dash unit pad, wiring and all then install as a whole unit. No steering column installed, then hook up your cables, speedo, and column
Logged
e-chal
Jr. Member
Reply #2 on:
April 26, 2010 - 10:06:53 PM »
Thanks Moparal for the reply. So on a bare dash frame, I should install the dash pad first, then all the wiring, instrument cluster, switches, bezels, etc.
Logged
Moparal
Permanent Resident
Reply #3 on:
April 26, 2010 - 10:33:47 PM »
I do it that way. There are some tight spots to get those little cap nuts on
Logged
e-chal
Jr. Member
Reply #4 on:
April 26, 2010 - 10:43:29 PM »
Thanks again Moparal for your help.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #5 on:
April 26, 2010 - 10:46:49 PM »
install the pad first then the wiring & guages & switches glove box etc
Logged
Slotts
Sr. Member
Reply #6 on:
April 27, 2010 - 08:13:04 AM »
You might consider building a dash frame jig first. It will make things a lot easier.
Slotts
Logged
e-chal
Jr. Member
Reply #7 on:
April 27, 2010 - 08:46:49 AM »
Thanks Chryco for the followup recommendation. Also to Slotts, thanks for the dash frame jig picture. I had already built a dash frame roteserrie, but my mounting connections are in the way for mounting the dash pad so I will use your jig idea. Again, Thanks to everyone.
Logged
nqkjw
Full Member
Reply #8 on:
April 27, 2010 - 10:20:10 AM »
Sounds like I did mine the hard way
Logged
Burnouts are cool but Traction is the Action
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
