Author Topic: Challenger consol install  (Read 635 times)
Offline HemiOrange70
« on: April 27, 2010 - 02:32:11 PM »
I am finally re-installing my center consloe . THe auto shifter plate doesn't fit flush with the conslo, I guess I need to shim it up or cut the crpet underneath away. Anyone else have this trouble?
Also, the v shaped spring that ttaches to the front shift linkage, where does the it hook to...the front linkage and the bottom bracket with the hole?
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
Re: Challenger consol install
« Reply #1 on: April 27, 2010 - 04:09:06 PM »
i believe the spring does attach to the bottom bracket..and i never had any trouble with the plate,,being to low,the top console plate always layed around the outer edge of the shift plate,,but if shims work there should be no problem,
72rtchallenger
what happens in the garage
stays in the garage
