on the upper control arm rotate the front adjustment bolt all the way out & the rear all the way in ,this will max the caster from there you may need to rotate the rear bolt slightly to adjust the camber ,set the toe in & you are good to go .
the adjustment bolts can be siezed in the bushings making removal very difficult & adjustment impossible , I alway coat the adjuster bolts with anti-sieze when I install them
