Author Topic: ECU bracket important?  (Read 1683 times)
Offline shadango
« on: April 28, 2010 - 10:12:02 AM »
I currently have my ECU (chrome Mopar) mounted dirct to the firewall.
I know that the cars with the ECU came with a bracket that mounted to the frewall and then the ECU mounetd to that.
How important is that bracket? :dunno:
Should I buy and install one?
Re: ECU bracket important?
« Reply #1 on: April 28, 2010 - 11:04:29 AM »
the first couple of years they did not use a bracket & most that I have seen mounted after as in non factory have been mounted on the firewall , the reason I think is to keep water running down the firewall from getting to the box & distroying the seal & shorting it internally so I think it i sa good idea to have the bracket but not mandatory
« Reply #2 on: April 28, 2010 - 09:12:47 PM »
I have one I'll send you, if you like.
« Last Edit: April 29, 2010 - 10:19:45 PM by dodj »
Offline shadango
« Reply #3 on: April 29, 2010 - 10:04:16 PM »
That would be cool.  WOuldnt mind being "legit"  :)
PM me and let me know how much you want for it, shipped.   :2thumbs:
Offline BIGSHCLUNK
« Reply #4 on: April 29, 2010 - 11:04:18 PM »
Mine' sright on the firewall..... I just stay out of the rain!  :bigsmile:  :roflsmiley:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline ragtopdodge
« Reply #5 on: April 30, 2010 - 12:00:35 AM »
Keep the firewall as clean as you can.
If you have a big-block, the OEM-style mounting bracket will bolt to the rear intake pan rail, so the unit is out of sight.  Not sure if it'll work on a SB.
http://www.rocketresto.com/electronicignitionbrackets.html
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline shadango
« Reply #6 on: April 30, 2010 - 05:37:21 AM »
 :22yikes:  Mounting the ecu on top the motor?  Is the extra heat OK for the unit?
« Reply #7 on: April 30, 2010 - 05:03:20 PM »
OEM from what year/body style?  :popcorn:
Never mind, I reread the post... :banghead:
« Last Edit: May 02, 2010 - 07:20:43 AM by dodj »
Offline ragtopdodge
« Reply #8 on: April 30, 2010 - 08:32:17 PM »
I don't think that area back there generates a lot of heat.  You don't see distributors melting on small blocks do you?
06 300c SRT8
04 2500 QCLB 4x4 HO
