Author Topic: Carb problem on 5.7 hemi  (Read 3578 times)
Offline UKcuda
  • Tell them I'm on my way
Re: Carb problem on 5.7 hemi
« Reply #15 on: April 30, 2010 - 03:43:42 AM »
it's not lash in the pump linkage is it ?
'72 'cuda
Offline heminut
« Reply #16 on: April 30, 2010 - 09:46:31 AM »
No, that is set up properly. I've thought about trying a different pump cam, but I don't know a thing about how the different cams work and would be getting into unfamiliar territory so I've kind of shied away from that.
1970 5.7 Hemi Cuda
« Reply #17 on: April 30, 2010 - 12:21:24 PM »
the pump cams have different rates of opening so that can help as well , I have a book here with a chart of the different ramp speeds if you need help
Offline heminut
« Reply #18 on: May 01, 2010 - 12:13:37 PM »
I'm probably not going to mess with the cams Neil, as I said that tech is over my head. One other thing I had considered was swapping carb bodies. I have a 600 (1850) body  and from what I've found on the subject on the net, using a 600 body with the 750 throttle plate will basically give you a 650 cfm carb. The 5.7 carbed crate motors are listed with a 650 vac. sec. carb. Apparently Mopar performance feels the 650 is a better choice than the 750? What are your thoughts on that?
1970 5.7 Hemi Cuda
« Reply #19 on: May 01, 2010 - 12:37:41 PM »
I would stick with the 750 & try to tune it out , as I said I can help you with cam selection
Offline heminut
« Reply #20 on: May 01, 2010 - 12:39:36 PM »
Sounds good. I'll work on the squirter first and see if I can do any good there. Thanks Neil!
1970 5.7 Hemi Cuda
Offline dodge freak 2
« Reply #21 on: May 02, 2010 - 01:22:06 AM »
How Mopar--GM, etc does stuff who cares? They ran both companies in to the ground and cheated many many people. Heck if I ever look to them for good advice.
Back in the old old days things were  different. Talking mid 1960 when they were running two AFB carbs on a 273 motor!
