Author Topic: Header Bolts  (Read 755 times)
Offline mojavered
  • Someday!
Header Bolts
« on: April 30, 2010 - 02:49:03 PM »
Will 3/4" header bolts be long enough with TTI headers and Indy EZ Heads?
Jason
Re: Header Bolts
« Reply #1 on: April 30, 2010 - 05:05:14 PM »
3/8th flange?  if you use a washer to, then no with a 3/8ths flange. I use 1 inch
Offline mojavered
  • Someday!
Re: Header Bolts
« Reply #2 on: April 30, 2010 - 05:12:06 PM »
Thanks Moparal.  I have some other headers on there for break in, and they must have a thinner flange.  The 1" bolts, with a washer (1/16"), are bottoming out with too much gap. Very disturbing.
Jason
Offline mojavered
  • Someday!
Re: Header Bolts
« Reply #3 on: April 30, 2010 - 09:53:54 PM »
The flange on the hedmans is 3/8" with a washer and 1" bolt, I am bottoming out on the EZ heads.  I still have my TTI's wrapped up, but am sure that they too have a 3/8" flange.  How thick of a washer are you using?  It seems that the 3/4" bolts are too short, even wo a washer.  Maybe I can grind down the 1" bolts?
Jason
Offline Strawdawg
    • Vortex Buicks
Re: Header Bolts
« Reply #4 on: April 30, 2010 - 11:18:48 PM »
why not measure the hole depth and figure out what it takes...or screw a bolt into the hole until it is bottomed and measure the the length inside plus the header flange thickness...and go from there...the washer should give you enuf to prevent bottoming afterward when torqued.
Or, use studs... :bigsmile:
Re: Header Bolts
« Reply #5 on: May 01, 2010 - 07:49:54 AM »
They do make 7/8th long bolts to, but make sure you get grade 8 or better.
