Sorry if this is a double post, computer is nearly as reliable as my car!
I burned out a single wire 100 amp March alternator. When it went out I could smell insulation or the alternator. Got new alt, tested it - OK, installed and aftermarket volt meter shows about 12V slowly dropping, and in dash amp gauge shows discharge. So I think this tells me that I am not charging the battery probably due to a fried wire between the alt and the amp gauge.
I used a test light from battery to alt, no power. So I think this tells me that I am not charging the battery probably due to a fried wire between the alt and the amp gauge. Does that sound right? I'm trying not to unwrap all my wiring and narrow the search down, any ideas?
Thanks, John
