Author Topic: Reality of a 6 pack?  (Read 5962 times)
Offline aris_unlimited
  • Project in full swing
« on: May 01, 2010 - 06:38:28 AM »
Hey guys I was just wondering in all reality if my wishes for a 6 pack are overrated? I have a 440 that will be built up to about 500 hp. I know that the 6 packs main carb is a 350cfm and the other two are 500cfm's. I was thinking I would make the main carb a 500cfm as well if that is necessary. Or in all reality would I be better off going with a 4 barrel? I would like to stick with a 6 pack if at all possible, but if it won't be able to manage the power I am expecting out of my motor obviously I will have to switch. Let me know you're thoughts, guys!
Cuda is gone :(
74 satellite, daily driver/project now
Re: Reality of a 6 pack?
« Reply #1 on: May 01, 2010 - 07:37:50 AM »
Making 500 hp with the stock 69-72 bb 6pk carbs is no problem. Also a 4bbl carb will do the job easier just by the tune.  I run a 6pk on my engine, I don't know why tho....maybe the wow factor or it was just what I had laying around at the time when I bought my car. I can say this. You will have more moving parts to keep working with on maintenance with the 6pk. They are not a problem if you know how to work on them and understand them. Don't expect to go much more than 6k rpms tho. But 500 hp is an easy number to achieve with any combo in air fuel you decide.
« Reply #2 on: May 01, 2010 - 08:12:13 AM »
Just a thought...seeing that this is not a resto & the large outlay required for a six-pack I'd look at this 6-bbl injection system  http://www.fbthrottlebodies.com/
Offline IMNCARN82
  • LeDZeP
« Reply #3 on: May 01, 2010 - 11:33:50 AM »
An EFI six will be very pricey right now. :money: I want one though. Heard they were over 6,ooo$!  Can't swing that.   So I still consider the carb. six. But am not sure on my skills with it.  R/T
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
« Reply #4 on: May 01, 2010 - 11:56:14 AM »
there are a # of factors here , first the 6 pack is rated as a 2 bbl not a 4bbl so the real flow rated as a 4 bbl is closer to 950 CFM total not that it will limit the power you want to get .
using a larger center carb is not really a benefit either , the small center carb has great throttle response & will get decent milage as well . The outboard carbs are difficult to rejet unless you get the Promax conversion plates .
Honestly I have found a single 4 bbl & the Holley Street Dom intkae or the Eddy RPM intake will make more power & cost less then the 6 pack , but having said that I also have a 6 pack on my 440 right now but  I also have a 950 HP carb & street Dom put aside if I decide to swap it out , the 6 pack looks killer for sure
« Reply #5 on: May 01, 2010 - 03:01:30 PM »
            :scared:    scared my mule
« Reply #6 on: May 01, 2010 - 08:55:19 PM »
I actually thought that 6-pack efi setup looked pretty good. But I'll be danged if I am going to spend $6k on it. I have found other efi setups for these for around $2k-$3k. As for the 6 pack system, I mostly want to do it for the "wow" factor lol. I am not a pro at tuning them or anything but that is something I can learn over time.......plus we have some really good mechanics out here that can help me with that kind of stuff.
Cuda is gone :(
Offline dodge freak 2
« Reply #7 on: May 02, 2010 - 01:11:19 AM »
Heck Edelbrock still makes a dual plane dual quad intake. Use two Carters or better yet Edelbrock AVS carbs.
Isn't too hard to tune. My D-66 dual quad SB runs--make that ran--very nice and smooth. I sold all my Holley and Demon stuff, lol
Offline challenger72rt
  • My l'il girl w' Dodge hat
« Reply #8 on: May 03, 2010 - 03:00:19 PM »
I used a single 4Bbl on my 440 and it had over 500HP - mated to a MoPar Performance aluminum intake it was an awesome set up.
Keep in mind that the 15 horsepower that was the difference between the 4 and 6 pak wasn't JUST carb, but the 4bbl 440 used 10:1 pistons, while the 6pak was 10.5:1.
I bored my block .030 over, and ran 11:1 forged pistons and again - the 4Bbl carb was awesome.
"Once upon a time I had a really bad Monday"
« Reply #9 on: May 03, 2010 - 03:34:50 PM »
Well a Holley Dominatior--race carb--which can be set up for street use by many custom carb shops--will make the most power. Scratch that--guess two Holleys on a tunnel ram will make the most power, LOL.
I would not worry about power--a 6 pack, dual Carters / Edelbrocks or one Holley will all be around the same HP give or take 20 hp.
Driveablity  will matter the most.
Which I feel the dual quad Carter / Eddys edge out, with the single holley a close second. Never had a 6 pack set up.
Offline 73Chally
« Reply #10 on: May 03, 2010 - 03:46:33 PM »
Other than the initial tuning and jetting, my 6 pack has not been touched in almost 4 years, with a couple thousand miles on it.  Power is plenty more than my tires can handle, so see no reason to need any more unless I wanted to put slicks on and race.  Zero issues with driveability, too.
Offline willhaven
« Reply #11 on: May 03, 2010 - 11:12:25 PM »
Website says $2,678. One of these is going in my car. I'll let you all know how it is when I get it.  :burnout:
« Reply #12 on: May 03, 2010 - 11:13:57 PM »
I set up a 340 6 pack on a AAR in 78 , it still has not been adjusted & runs great
Offline 73Chally
« Reply #13 on: May 04, 2010 - 10:08:32 AM »
I think the $6K comes in if a shop does the entire install and tuning, especially if done on a chassis dyno.  Once these things are set up (carb or EFI), they don;t change on there own, so a lot of people who say they suck are probably trying to tune them themselves with no experience, or were never set up right to begin with.  Altitude could also have an affect, but that would take a pretty significant change, like moving to Colorado from Texas.
Offline 500Stroker
« Reply #14 on: May 04, 2010 - 10:11:04 AM »
  I don't think that is a turn key kit for that price.
