Author Topic: Fuel tank filler tube paint  (Read 3038 times)
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« on: May 02, 2010 - 06:09:36 AM »
I read on another thread it supposed to be natural steel.  however I stripped off the black trunk paint someone put there and it appears to be brush painted silver.  What is correct?
Offline 67vertman
  • Member since 9-23-2005
Re: Fuel tank filler tube paint
« Reply #1 on: May 02, 2010 - 08:51:36 PM »
Mine, 70 Barracuda, natural steel.
« Reply #2 on: May 02, 2010 - 09:04:52 PM »
My '73 was galvanized, not the shiny slick more of a dull gray that rubbed off easily.
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #3 on: May 02, 2010 - 09:30:40 PM »
Maybe mine is galvanized.  It looks painted an and paint stripped did not touch it.  I scratched it up changing out the tank seal and want to fix it up.
« Reply #4 on: May 03, 2010 - 10:27:17 AM »
I have used Eastwoods Detail Grey to simulate the natural steel finish
Offline swede-cuda
« Reply #5 on: May 03, 2010 - 10:38:00 AM »
 :wave:shouldnt that part be led-dipped or tinned??dont know if i got the swenglish right there but i bet your with me.from minimizing the risk of sparks when filling up the tank?hmm :clueless:
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #6 on: May 05, 2010 - 03:53:30 AM »
Hmm I wonder if it is dipped in lead.  Thats what it looks like and stripper does not touch it.
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #7 on: May 05, 2010 - 11:46:42 AM »
My 71 I just took off has nothing on it aside from some red overspray.
Looks like untreated metal.
« Reply #8 on: May 05, 2010 - 11:58:09 AM »
They were origonally lead dipped.  That process has been outlawed by the EPA.  If your tube is free from dents and deep scratches, you can use some fine steel wull on it.  That will bring back a lot of its natural color.
« Last Edit: May 05, 2010 - 12:01:44 PM by burdar »
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #9 on: May 05, 2010 - 12:48:32 PM »
Lead dipped it is then.  It has some scratches.  When I detail out my trunk I'll put a torch to it and see what happens.  <After the gas fumes are out>
« Reply #10 on: May 05, 2010 - 04:58:07 PM »
You'll melt the solder holding the inner thing that's at the tank end. (at least  on my '73).
Don't ask me how I know.  :-\   .....I'm thinking weld through primer might do the trick.  :dunno: Everything I've tested so far is melted by gasoline.
Offline ntstlgl1970
  • T a c o c a t
« Reply #11 on: May 05, 2010 - 05:22:19 PM »
Used steel wool on mine and it looks very nice, not going to mess with it any further.
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #12 on: May 05, 2010 - 08:49:06 PM »
Good point bullitt.  I scratched it up a bit getting it in without dropping the tank.  i know sort of half a$$ED..  I'll try some steel wool if/when I pull it out next time.  The trunk is coated with undercoating on the inside, probably because the rear window leaked, and instead of fixing the source, they fixed the symptom.  Typical of the work done on the car.  One of these days I'll redo the trunk most likely when I paint the whole car.
Offline ShelbyDogg
« Reply #13 on: May 15, 2010 - 12:48:29 PM »
I painted mine light machine grey.   It looked like Chrysler was lazy when they didn't paint it.
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
« Reply #14 on: May 16, 2010 - 03:36:27 AM »
That looks good.  Stupid question, what is the other tube for?
