Author Topic: Front of transmission leaking  (Read 1301 times)
Offline 500Stroker
« on: May 02, 2010 - 05:54:26 PM »
On the way home from a short drive yesterday I noticed all kinds of smoke in the rear view mirror.  Got the car home and parked in the garage.  Jacked her up and found this
The fluid is comming out of the front inspection cover.  It is not the pan gasket.  Have to drop the trans one night this week.  What will I most likely need to replace so I can pick up parts ahead of time.  The trans was rebuilt 2 years ago.  Still shifts as hard as day one.
Re: Front of transmission leaking
« Reply #1 on: May 02, 2010 - 06:29:08 PM »
I had a similar problem once. The torque converter seal on the front went to heaven. The fluid traveled down my exhaust pipes burning white smoke, and putting tranny fliud up on my rear bumper.    :pullinghair:
« Last Edit: May 02, 2010 - 06:34:18 PM by MEK-Dangerfield »
Offline 422STROKER
  • Member Since 6/3/06
« Reply #2 on: May 02, 2010 - 06:33:01 PM »
Did you pull the inspection cover?  Maybe if you get real lucky it's the converter drain plug.
Tom :drunk:
Tom
Offline 500Stroker
« Reply #3 on: May 02, 2010 - 09:10:41 PM »
No such luck...No drain plug on the converter
Offline moprr
« Reply #4 on: May 02, 2010 - 09:43:42 PM »
I had the same thing happen to me and I lost a lot of fluid.  I filled it up hoping to get home and now about
4000 km later it never leaked again.  I was told that dirt may have got into a seal?
Offline Aussie Challenger
« Reply #5 on: May 02, 2010 - 11:56:00 PM »
Looks like the front seal but check the front pump bolts first. If the front pump bush has excessive clearance the seal doesn't have much of a chance.
Offline tactransman
« Reply #6 on: May 03, 2010 - 08:56:08 AM »
For it to be leaking that bad when it was fine,I think you must have spun the pump bushing out in the pump body behind the front seal.
Terry-tactransman
Union, Mo.
Offline 500Stroker
« Reply #7 on: May 03, 2010 - 12:11:59 PM »
Thanks for the info.  I'll take a good look once I get it out of the car.  It did start all of a sudden.  Bone dry for 2 years since the rebuild and then bam a bad leak during a mild 15 minute cruise.
« Reply #8 on: May 03, 2010 - 07:39:51 PM »
Just a comment, as I have a bone stock auto I always start in neutral so that trans is circulating oil straightaway, if I was to leave the auto in when I up grade I would fit the different spool so that trans has pressure in park.   :2cents:
Offline 500Stroker
« Reply #9 on: May 13, 2010 - 11:00:38 PM »
Finally got it out and found my problem.
Man that sucker is long and heavy with the Gear Vendors on there.
This is the convertor with water on the top, input sealed off and getting ready for a pressure test after being removed from the sink.  Crappy cell phone pic.
test started...notice the air bubbles.
I'm leaving on Wednesday for the Ocean City, MD show so I'll have to put my old converter back in to get the car on the road for now.
Offline tactransman
« Reply #10 on: May 14, 2010 - 07:25:21 AM »
 :2thumbs:
Terry-tactransman
Union, Mo.
