Author Topic: 73 Challenger hood hinge rivet replacement  (Read 1815 times)
Offline 71340RT
« on: May 02, 2010 - 11:29:19 PM »
 I've bought new rivets for my hood hinges and was going to take the old ones out but I was only sent 10 rivets and there are 7 rivets in each hinge not 5 like I was sent. I figure that 2 of the rivets must not wear so you they don't need to be replaced. Here is a picture of one of my hinges and if anyone knows which ones wear out let me know.
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Offline Chlngrcrzy
Re: 73 Challenger hood hinge rivet replacement
« Reply #1 on: May 03, 2010 - 12:18:15 AM »
You found rivets for those things   :clueless:  wow. i guess i didnt search around enough. I finally bought a set of new ones, which i had to take one to a machine shop and have fixed. The manufacture put the bar that attaches to the hood on upside down. No way was it ever going to fit. I should have sent the darn thing back, but it didn't cost me any thing to get it fixed. Pays to know the right people.  Good luck on your hinge rebuild.   :2thumbs:
OxfordMotorSports
« Reply #2 on: May 03, 2010 - 12:25:28 AM »
You have two "PIVOT PINS" on each of your hinges. They are the two that have the slots around them. The other five on each hinge are true rivets. Just replace those five.
Offline 71340RT
« Reply #3 on: May 03, 2010 - 12:52:00 AM »
Thanks for the reply that realy helps out.
OxfordMotorSports
« Reply #4 on: May 03, 2010 - 03:54:38 AM »
No problem. Good luck with the fix. Where did you find the rivet set? Others might want to know.
Todd
OMS
Offline nqkjw
« Reply #5 on: May 03, 2010 - 05:52:01 AM »
I had my hinges redone by a machine shop over here.
They used oversize rivets because the links were worn as well.
Just replacing the rivets wouldn't have cut it.
They're good now though :2thumbs:
Burnouts are cool but Traction is the Action
Offline 71340RT
« Reply #6 on: May 04, 2010 - 11:10:20 AM »
I bought mine off ebay from user name restoguygordon. I checked and he does not have any auctions going on right now. They are oversize so they will have to be fitted to be installed. I was not sure till they came if they were going to work or not.
