Author Topic: Rust around hood hinges. Looking for repair panel??  (Read 4569 times)
Offline cudadave72
  • you motorboatin sob!!!
« on: May 04, 2010 - 02:34:01 PM »
I couldn't stand it any longer and started poking around at the rust that was around my hood hinges. I thought I saw there was a repair panel instead of replacing the entire apron. Where do I find these??
Thanks
1972 BS23 H code Cuda, B5 blue, 340 streched to 416 cu in, 727 w/ 8 3/4 rear, 7.23 in the 1/8 mile and 11.38@117mph in the 1/4 on drag radials   Under restoration! Coming soon... 440cuin R3 Indy SMALL BLOCK monster!!!!
Re: Rust around hood hinges. Looking for repair panel??
« Reply #1 on: May 04, 2010 - 03:07:11 PM »
Year One used to sell that piece.  I havn't looked through their cataloge in awhile so I don't know if it is still available.
OxfordMotorSports
« Reply #2 on: May 04, 2010 - 04:22:00 PM »
Thanks
It's not a HARD piece to fab up in sheet metal. I just did the same repair on a 71 Cuda . Cut the rust out, punched holes in the new metal, passed on a flange, welded it in flush.
Lesson learned? Find the repair panel. It's a lot LESS work.
Todd
OMS
Online RUSTY Cuda
  • One big step foward!
« Reply #3 on: May 04, 2010 - 06:20:09 PM »
There out there I got one for the drivers side, but had to make up the part that slides around for adjustment, on the other side I bought the whole inner fender , but the metal where the hinge bolts in is thinner. So there's some extra work either way.
this was before amd, check them 1st there stuff seems to be higher quality, Rich.
Offline 73EStroker
« Reply #4 on: May 04, 2010 - 10:20:47 PM »
Goodmark has em. Horrribly expensive but they have compound curves in them so are really difficult to make accurately. They have the correct holders of course to contain the cage nut bar that holds the hinge bolts and allows them to slide around in for adjustment
Barry (Salmon Arm)
Offline E-Body Products
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #5 on: May 04, 2010 - 10:43:50 PM »
PM Sent...
Offline R/T hedkace
« Reply #6 on: May 04, 2010 - 11:26:06 PM »
Hey Dave, I don't know how much of, or how bad your is, but this is a VERY common spot on e bodies, and funny you should mention this. I just got on this piece on my Chally a few hours ago today and started welding in a piece I cut off of a junk 72 fender.
 There is actually 3 different pieces you should be aware of that make up the front hood hinge adjustment plate(s) for the front bolt for the hinges.
I'm not quite done yet, but if I can do it, ANYBODY can do it. Seriously dude  :thumbsup:
Pretty easy......and I'm an idiot when it comes to this stuff  :eek4:
 Here's some pics to give you a better visual and to maybe help you out a little  :dunno: :cheers:
And if you need any other pics for reference, just let me know  :wave:
Jeff
    Defending the Earth from "uptight" mods!!   an endless crusade..........
1970 Dodge Challenger R/T 440 4speed Dana
1970 Dodge Super Bee
1969 Barracuda
 Massachusetts
Offline acudanut
« Reply #7 on: May 05, 2010 - 02:34:31 AM »
It's alot easier just to replace the whole inner fender. :2cents:
Offline cudadave72
« Reply #8 on: May 05, 2010 - 03:27:39 AM »
Thats not an option. Being that my car is in overall great shape and this being the only "major" concern I'm not going to tear the entire car apart. Being that my wife and I just had twins if my car come that far apart then I will end up tearing the entire car apart and it will be years before its back together. The way it sits now its a perfect driver and still quite a looker. The damage is not that bad and I have even concidered something like a Por15 filler in the damaged area, patch it and let it ride until I do a full resto. I'll know the full extent of the damage once the hood hinges are off the car and I guess I take it from there. If I rock the hood back and forth the area around the hinges does not flex one bit so I feel pretty good about that.
Offline the_engineers
« Reply #9 on: May 05, 2010 - 05:33:32 AM »
 :useless:
Do you have any pics of how it looks now?  The pics that hedkace posted look to be a fairly simple "pull the hood, cut out the bad, put in good, paint and reinstall hood" type of deal.  I could see it being a week-long ordeal in the evenings if you've got the materials and a welder on hand.
« Last Edit: May 05, 2010 - 05:35:46 AM by the_engineers »
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
OxfordMotorSports
« Reply #10 on: May 05, 2010 - 02:47:43 PM »
You did the right thing. Un-seaming the entire panel is not necessary if it is completely solid other than the hinge area. It just takes more fab time to do a proper patch repair. By the way Jeff - your work looks EXCELLENT. It's a straight forward repair and if you have the time to do it in this manner go for it.
Todd
OMS
« Last Edit: May 05, 2010 - 02:50:53 PM by OxfordMotorSports »
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #11 on: May 05, 2010 - 11:20:54 PM »
By the way Dave, your cuda looks great!   Wish mine was looking that good right now!
OxfordMotorSports
« Reply #12 on: May 05, 2010 - 11:43:01 PM »
They ALL look good. Nothing beats a Cuda or a Challenger. Nothing!  :ylsuper:
Todd
OMS
