Author Topic: Washer Bottle/Pump/Hoses/Squirters Drawing or Picture for 70 Challenger?  (Read 14149 times)
Is there a Drawing or Schematic for this?
Does the Electric Pump Outlet face forward?
Even a pic from someones car would be great. Thanks
« Last Edit: May 07, 2010 - 12:38:36 PM by 1970 RT Challenger 1970 »
the factory service manual should have an illustration , the motor on the bottom of the washer bottle usually faces the rear of the car , the hose to the hood goes through the hole in the cowl lip above the wiper motor , there is a special Tee that snaps into the hood & send the fluid out the the 2 squirter pipes screwed to the under side of the hood that poke through the grille at the back of the hood
I have the complete kit to install:
Which path does the hose from the washer bottle/pump follow:
1. To the battery area then the vacuum booster/master cylinder
and then to the hood center?
2. Straight back to the passenger side windshield and to the center of the hood?
Thanks.
it comes up behind the horns & goes back on the passenger inner fender , across the firewall clips & up behind the wiper motor & through the hole in the cowl lip to the tee in the hood
Offline BIGSHCLUNK
I can take some pics if you like.... altho my wiper motors currently out...
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Pics would be Excellent, Thanks!
Offline ShelbyDogg
My electric pump outlet faces down towards the framerail.  The motor housing faces the firewall.
Offline BIGSHCLUNK
Crap... forgot about this, I'll try for tomorrow...  :banghead:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
The plastic tie wraps in the hose kit push into the holes on the inner fender? Thanks
Alaskan_TA
Different types of pumps were used, from memory there are at least three types for 1970 E body models alone. Not all of them face the same way.
Offline ndrewoods
  • Newbie
Does the Electric Washer Pump Outlet face forward?
Bumping an old thread. Kinda need a schematic for this as well. Need it for my washer pump. Anyone here has one? Appreciate any posted pics.
« Last Edit: May 29, 2011 - 01:29:27 AM by ndrewoods »
Offline Matt70
Here are some pics, screw driver is on the washer fluid line. Hope this helps.  Matt
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf.
George Orwell
Offline DAYLEY/CHALLENGER
Hey Matt...... Looks like you have a lot of orig . equip under the hood.  Nice pics too of the routing.  I am missing the T part...............
Dave or David
Offline Matt70
Hey Dave, yeah thanks. It was a 318 now a 360, but I think a 440 is in it's future  :burnout: I'm jealous of your RT/SE  :grinyes:
Take it easy,  Matt
George Orwell
Offline quapman
    • Auto-Grip on Facebook
I've never seen the hose go through the hole in the wiper motor shield.
