Author Topic: Power Brake Booster E-Body  (Read 907 times)
Offline 440 challenger
« on: May 06, 2010 - 08:25:04 AM »
Can someone give me the measurements of the firewall bolts on the brake booster for E-Body? Want to put Hydroboost on and trying get correct parts before I start. Does any one know if you have to remove the linkage under the dash? I got a HB unit from a '94 Astro van yesterday for $20. It looks like a big headache  getting the power booster off. May not be worth the trouble. I want the extra room to get valve covers on and off easier. I have a 440 with M. P. valve covers
« Last Edit: May 06, 2010 - 08:33:42 AM by 440 challenger »
Re: Power Brake Booster E-Body
« Reply #1 on: May 07, 2010 - 02:44:05 AM »
73 E stroker should have all the info you need , he did exactly the same swap on his Chall
Offline GreenFish
« Reply #2 on: June 29, 2010 - 09:55:53 AM »
ITs been a while but I converted from power to manual brakes. I dont remember the booster being hard to remove.
