Author Topic: shift r gate...anyone know good or bad experiences??  (Read 2833 times)
Offline challydust
« on: May 06, 2010 - 02:11:48 PM »
seen a while back on the web somewhere about a company making this product...suppose to install under ur slapstick, for a no mistake, shift pattern??  im interested in this if anyone knows about it....im constantly short shiftin my reverse valve body under heavy acceleration.... :burnout:.....wonder if this product will help me...thanks everyone!
Offline Jim
Re: shift r gate...anyone know good or bad experiences??
« Reply #1 on: May 06, 2010 - 03:40:54 PM »
Shift-R-gate is for forward pattern VB. It sort of converts a non-slap-stick to a slap-stick. It's marginally effective... at least the one I purchased several years ago for my 69 Charger was. Don't know if the design has been improved upon since.
-Jim
"Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. "
Offline challydust
« Reply #2 on: May 06, 2010 - 04:02:56 PM »
Thnaks magnum....they make a reverse valve shifter gate too i see on there site....my car is already a slapstick...i was just wonderin if the shifter gate was an improvement...or basically the same thing i have from the factory....when i shift mine which again is reversed...i sometimes slip from 1st to 3rd....accidentally...its easy to do in mine...maybe my slapstick isnt right? or broke...ive never owned another so i wouldnt know anydifferent ...would like just a more positive shift, or where i cant short shift it.....
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #3 on: May 06, 2010 - 04:25:47 PM »
I don't get in my car regularly but if you don't push the button, you should only go from 1 to 2 gear, not into 3rd if your shifter is working properly... I think.
Offline challydust
« Reply #4 on: May 06, 2010 - 04:36:30 PM »
yeah super blue...mine prob isnt right then....i short shifted it twice this morn...driving to work, crankin on it!...lol....again mine is reversed valve body...so i pull mine inot D (1st) down to 2 (2nd)  then to 1 ( 3rd high gear)...teh problem is when ur all into it and stuff...watching the rode, the tach, gettin er sides ways...lol...its easy to pull it right from 2 to 3rd and right outta the power band...the car still has a ton of balls when i do it...but it really churns when its shifted properly obvisouly...lol
Offline 73Chally
« Reply #5 on: May 06, 2010 - 05:55:20 PM »
The Chrysler Slap Stick is pretty much the best automatic shifter available back then from the factory.  If I was still running my automatic, I would not have done anything to change it.  If you're having problems with yours, then it is something in the mechanism, as opposed to the nature of the shifter itself.
Offline challydust
« Reply #6 on: May 06, 2010 - 06:01:22 PM »
yeah chally thats what im thinkin....do u think it has anythign to do with it being reveresed vb....and its the sequence of the shift...as far as why it can go from 1 to 2 in one swift motion.......i would think there should be a stop there...so that wouldnt happen....any suggestions would be great.... :clapping:
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #7 on: May 06, 2010 - 07:00:38 PM »
the slap stick works coming from low to 2nd to 3rd,,but if yours is set up as a reverse valve body and your shifting down to first on the shifter to get 3rd it wont work as the shifter is set up to do it in a forward motion not back
72rtchallenger
what happens in the garage
stays in the garage
Offline challydust
« Reply #8 on: May 06, 2010 - 07:08:19 PM »
Yes Rt, I thought that may be the reason...its just not set up for that....i bought the car that way with teh rev vb.....I really wonder why anyone would want the vb to be in reverse anyway....its just so easy to slip it into high gear that way....thats alot of lost races!..lol.....guess i could always change it to a full manual reg shift vb huh.....thanks everyone for the input...this site is very helpful and everyone extremely cool on here...... :cooldancing:
« Reply #9 on: May 07, 2010 - 10:32:04 AM »
A little off topic but another cool shifter was found in some 2nd gen Trans Ams.  My sister had an '81 Trans Am and had a ratchet shifter in it from the factory, similar in action to a Slap Stik.  It wasn't label like a Slap Stik to show you it was there except for an elongated hole on the plastic dust shield that moved with the shifter.  When you drop it in 1st gear, you push it to the right about 1/2" and it would only ratchet up 1 gear at a time without hitting the shifter button.
I thought it was pretty cool and I think it only came on WS6 models as my brother's regular '80 Turbo Trans Am did not have this type shifter nor the elongated hole in the shifter dust shield.
« Reply #10 on: May 07, 2010 - 12:07:08 PM »
Quote
The plate you are talking about should solve your problems.  The factory slapstick is obviously set-up for a stock pattern.  It doesn't work backwards.  The plate will make your slapstick work just like the factory intended...but in reverse for a reverse valve body.
With the new plate, you should be able to put the selector in D(1st) and slam it back into 2(2nd) and have it lock.  Let up on the shefter a little and them slam it back again into 1(3rd).
Offline challydust
« Reply #11 on: May 07, 2010 - 12:40:33 PM »
thanks man!!!!...I think I'll try one then...makes sense......cool..... :bigshades:
