So I decided to change the oil tonight, since I still had the cheapo oil in there from when I reassembled after my "rag" incident. No issues there aside from fighting the #&$(^% oil filter to get it off. LOL
As I was cleaning up I hit the tire with my hand and VIOLA! there was that annoying noise that I have been hearing over stutter bumps etc......I spent a good hour searching for it, thinking it was my shock or balljoint or something.
Well, I FINALLY figured it out.....it is this....
At the points where the arrows are, it seems that the spots welds have broken and that whole side of the "brace" is loose . .... .
It looks like it reinforcies the vertical rise of the shock "tower" to the top of the inner fenderwell....
So, how bad is this? My guess is that its been like this since I got the car.....it doesnt look loose..only if you grab it hard will it move.
I was thinking of welding a bead along those two areas......of course that means that I will mar the engine bay paint....
I could just use some bolts I guess, but that wouldnt look right either......
I assume this is serious.....but how bad off am I here? Dead in the water serious or just get to it when I can sort of deal? I know unibody cars depend on all sorts of bracing etc to work as a unit.....
