My Suspension Changes (Long)
Author Topic: My Suspension Changes (Long)  (Read 11890 times)
Offline FJ5_440
  • Wisconsin
« on: May 07, 2010 - 09:58:48 PM »
I have been putting together a suspension set up for my 70 using advice and tips from the track going guys on the board and a couple of friends who run vintage cars around Road America once in a while.  I have had a couple of mild Pro touring rides that handled very well even compared with some modern cars. and of hoped I could come up with something similar without having to go to the XV level 1 or Hotchkis stuff..
Before I started the upgrades, everything on the car had been restored or rebuilt, so I think it was probably a good representation of a new stock car.
Bolt in sub frame connectors-
I got a pair of the dual tube floor hugging type from Magnum Force ($259).
I didn’t expect too much, and was more concerned about dealing with some of the sail panel cracking I was experiencing.  Even though they are currently bolted in, they did make a big difference in the “solid feel” of the car.  I still plan to weld them in later this summer.
Front sway bar-
The car came without a front or rear sway bar, and had .920 torsion bars.  It handled like a cement truck.  With the addition of the 1.125” front sway bar, the handling improved greatly.  I tried using a G meter app on my iPhone, but couldn’t get data worth posting with my backyard methodology.  The reduction in understeer was impressive.  Now it handled more like a mid sized SUV, and didn’t threaten to scrape the gills off of the rocker panels on every tight corner.
Rear Sway bar-
I added a stock E body rear sway bar with poly bushings and end links.  To be honest, there wasn’t too much difference compared to some of the other modifications.  I do think the car felt more predictable in hard turns though.
Brakes-
I started out with stock 10 inch drums in the back and stock discs in the front.  My backyard measuring tape 60-0 distance averaged out at right around 152 feet, with surprisingly little drama although I think the back brakes locked a little earlier than I expected when the weight shifted.
I did the 11.75 inch brake swap and used the following parts:
Brake Caliper - 78 Cordoba Slider type -$36 bucks at Advance Auto
Brake Caliper Support - 78 Cordoba Slider type -$100 bucks on EBay
Brake Discs - 11.75 inch 78 Cordoba Drilled and Slotted -$135 bucks on EBay
Brake Hose - 75 Dart -$32 bucks at Advance Auto
Brake Pads - 78 Cordoba semi metallic -$22 bucks at Advance Auto
In normal use, it was a little more positive when hard braking, but the improvement wasn’t too apparent until I did the 60-0 again and posted about 11 ft shorter distance.  The fade resistance was another noticeable improvement, especially doing the repeated stopping tests.  They seem pretty well matched to the stock rear 10 inch drums even without an adjustable proportioning valve.
NOTE- The new rotors were zinc washed and very shiny, but the area between the bearings still had a ton of casting sand in it.  If this wasn’t cleaned out, the abrasive sand may have made it into my bearings and made for an interesting drive.  I also installed new TIMKEN bearings and their races into the rotors.  The bearing races that came with the rotors were zinc washed with everything else and I didn’t trust them.
Torsion Bars-
The car had a new set of Mopar Performance .920 bars on it.  It wasn’t terrible, but I knew that more spring rate would help a lot.  Just Suspension 1” torsion bars helped a lot.  The ride didn’t seem to suffer at all, and the adjusters still let the car go low enough to rest on the bump stops if you want.
Shocks –
The car had a new set of Monroe gas charged shocks on it.  I thought they were fine, but the difference that the Bilstein RCD shocks made on ride quality and handling was drastic.  I was skeptical about a set of shocks being worth the $400, but I am a believer now.  I think they handle much better than the old KYBs, and they ride as smooth as the Monroes.
Steering Box and fast ratio pitman and idler arm –
I installed a Firm Feel Stage 3 Power Steering box as well as the fast ratio pitman arm and idler arm.  It may be the best modification I have made so far.  It is actually a bit stiffer than I expected, but gives the car a much more modern feel.
NOTE- The fast ratio pitman arm also allows the wheels to turn in and out farther than stock, so now my 245/60/15 fronts will rub the frame rail if I turn the wheel the whole way.
All together as a package, these modifications made the car feel like a completely different vehicle.  It is a pleasure to drive even on curvy roads now.  With the stock upper control arms, I was able to get almost 4* caster at 0 camber.  I have a set of Moog Offset upper control arm bushings that I might install to get even more.  Modern 17” wheels and tires would make a big improvement too, but I don’t want to ruin the stock look of the car.  If I had to pick just a few items from my list, I would do the frame connectors, the front sway bar and the Firm Feel steering box first, but skip the fast ratio idler arm.  Next would be the 1” torsion bars and shocks and the rear bar.  Unless I was going to run the car really hard I would consider the brakes optional because I didn’t really consider the stock set up that bad.
** Shane **
Re: My Suspension Changes (Long)
« Reply #1 on: May 07, 2010 - 10:05:00 PM »
Great info ...  :clapping:
Offline Katfish
  • 70 Challenger
« Reply #2 on: May 07, 2010 - 10:30:37 PM »
Good info,  got any more info or pics of the subframe connectors?
Thx
Offline RusTy/SE
  • Just havin' fun
« Reply #3 on: May 07, 2010 - 10:45:40 PM »
 :iagree: Great!
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline _Russ_
  • Not very family friendly!
  • Chk Chk Boom!
    • Show Me How To Live
« Reply #4 on: May 07, 2010 - 10:55:30 PM »
Good info!
Offline FJ5_440
  • Wisconsin
« Reply #5 on: May 07, 2010 - 11:04:00 PM »
Thx
I had used several sets of the Mopar Performance subframe connectors in the past, but found that they took a fair amount of tweaking to fit nicely and still tended to protrude a bit low in the rear.  The type that weld onto the floor pans would have been my first choice, but the car had already been on a rotisserie and I didn't want to mess up the floor pans again.  Also I am not a good welder and would have never gotten a clean install welding that much on my back.  The Magnum Force racing connectors have a bend in them that keeps them hugging the floor, and even have a bolt on plate that sandwiches the floor pans behind the front seats adding rigidity to the whole floor.  I am not sure how they perform compared to the other types, but they seemed to work wonders on the feel of my car.
  http://www.magnumforceracing.com/store/detail.asp?ProductID=3035&CategoryID=19&BrandID=&Category=&SubCategory=&Search=&Page=
** Shane **
Offline Road_Runner
« Reply #6 on: May 08, 2010 - 12:19:34 AM »
This is terrific info, and I really appreciate the change by change comparison.  I'm probably going to go down a very similar path with mine, and will do this a change or two at a time as funds allow so your ranking of the changes is a great help.  Like you were, I'm a bit skeptical that expensive shocks can be that good a 'bang for the buck' kind of change, but based on your comparison I probably should rethink that.
Thanks again, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline Strawdawg
    • Vortex Buicks
« Reply #7 on: May 08, 2010 - 12:46:27 AM »
Thanks for the write up :)
What rear springs did you use?
« Reply #8 on: May 08, 2010 - 07:16:54 AM »
Thanks for posting!  :2thumbs:
At the end you said you would skip the fast ratio steering arm. Is that because the wheels can make contact with the frame at full lock, or does the steering just not feel the way you would like?
Offline FJ5_440
  • Wisconsin
« Reply #9 on: May 08, 2010 - 08:58:42 AM »
I used a set of +1 inch rear springs from Espo, because I like the slightly raked look. Now that the 1" torsion bars let me lower the front, I will end up dropping the rear with a Mancini rear spring hanger to keep the rake I like, just a couple inches closer to the ground.
** Shane **
Offline FJ5_440
  • Wisconsin
« Reply #10 on: May 08, 2010 - 09:13:40 AM »
The steering feels great but I would skip the fast ratio steering next time mostly because it cost $300 for the Pitman arm and idler arm and I personally don't think the quicker steering is that necessary for a cruiser like mine.  The tire rubbing is only an issue at full turn like a parking maneuver or a U turn.
I went from the  70 type steering box to the later one for the increased shaft size, so I needed a new pitman arm anyway and decided to try out the fast ratio stuff.
** Shane **
Offline Strawdawg
    • Vortex Buicks
« Reply #11 on: May 08, 2010 - 09:50:21 AM »
I agree with you :)
These were the XHD springs from Espo?
Offline BIGSHCLUNK
« Reply #12 on: May 08, 2010 - 10:04:25 AM »
Shane, great write up here. Lots of good info for others to set a base line from!  :2thumbs:
« Last Edit: May 08, 2010 - 10:16:46 AM by BIGSHCLUNK »
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline FJ5_440
  • Wisconsin
« Reply #13 on: May 08, 2010 - 10:12:21 AM »
I agree with you :)
The Mopar Performance XHD springs were initially installed on my car, and the ride height was just like stock until the springs "settled" and gave the car a droopy bottom look.  The springs I got from ESPO Springs n things were made to have an additional 1" arc over stock, and didn't settle significantly.  I highly recommend Espo if you need springs.
** Shane **
Offline BIGSHCLUNK
« Reply #14 on: May 08, 2010 - 10:19:10 AM »
I'd like to see your "rake" (not to mention your ride) sometime Shane. I have the XHD's and I like my rake, maybe I'm just lucky as my buddy's XHD's did not seem to have the same arch.
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
