Author Topic: Floor patch recommendation  (Read 1190 times)
Offline JonS
« on: May 08, 2010 - 05:46:48 PM »
I'm getting ready to order metal to redo my floors which it seems everyone ends up doing on these cars.  The transmission tunnel area is good but everything else is pretty thin or gone.
I've had recommendations to do 2 - 3/4 length pans on either side of the tunnel instead of the whole floor pan over concerns that after removing the floor there is a chance you can twist up the body because of some of the rigidity that you lose.  Any truth to this or am I getting advice from people that are paranoid?
If I did the full pan then at least I could pretty much match the locations of the factory welds.
I appreciate the input.
Jon
Offline CudaNut
  • She's so fine ain't no tellin where the money went
    • CUDANUT.COM
Re: Floor patch recommendation
« Reply #1 on: May 08, 2010 - 06:03:59 PM »
If the rest is gone or thin the rigidity is gone anyway. If you can level the car and support it properly (multiple points) the full pan is the best way. I've replaced a couple of these and in my opinion the full pan would be easier than trying to splice the floor with the two 3/4 pans. Post a pic and it would help us evaluate the situation.
"If I had my life to live over again, I'd be a plumber."
  Albert Einstein
Offline DetMatt1
« Reply #2 on: May 08, 2010 - 06:20:32 PM »
I would definitely go with the full pan as well, you will be much happier with the end result. Is the rest of the car solid, rockers, frame rails etc. and how do your doors fit, as far as gaps?. If all of this is good, than I'm sure you will have no worries. Pics would help.
Offline JonS
« Reply #3 on: May 08, 2010 - 06:51:03 PM »
Here are a few pics for you...
Basically, the low areas are trash, but anything that isn't a low area is surprisingly good.  The back seat is pretty good except on the passenger side where your butt goes.
To continue with more questions... I've looked at Goodmark, AMD, and now Dynacorn for metal.  A local restorer is telling me that Dynacorn metal is better than AMD for quality.  I'm not sure if anyone here has experience with it or not.  I'm always weary of what someone sells when they don't sell anything other than what they're trying to sell you.
Offline 72cudamaan
« Reply #4 on: May 08, 2010 - 07:18:17 PM »
Careful there,  your pics show 4 different pans needed to fix what damage you have.  The front floor pan does not include the two rear footwell pans, and the area where your "butt" sits is actually another whole piece.( unless you can make a patch for that part.
 Your tunnel looks like it has a lot of rot, so I would probably put a whole front pan in anyways.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline JonS
« Reply #5 on: May 08, 2010 - 09:56:22 PM »
72,
You are correct; the rear foot area needs replaced, the back seat is better than 75% there so I'll end up saving it.
The tunnel is actually deceptive.  There is no rush there and it is 100%.  The area that looks like rot towards the back is just dirty and also has some of the factory sealer.
Is there anyone that wants to take my buddies position that it is better to do the 2 - 3/4 panels or is he alone?  Any comments on the Dynacorn metal?
Thanks again,
Jon
Offline CudaNut
    • CUDANUT.COM
« Reply #6 on: May 08, 2010 - 10:21:24 PM »
I would clean or blast the shell and evaluate where you are at before buying any metal. How are the frame rails? The inner fenders? Other metal? From what I see you need at least all the interior pans, trunk pan and that rear under seat pan is not that hard to replace. Rust you can't see is what you have to worry about... As far as brand goes I recently used a complete set of pans from Sherman (generally same as Goodmark) and they fit fairly well at much less cost than AMD. I have not used Dynacorn. There are several dealers here on the board for metal that could save you some $$$ but get a good evaluation first.
  Albert Einstein
OxfordMotorSports
« Reply #7 on: May 09, 2010 - 12:44:48 AM »
www.ebodyproducts.com
dj1965@ebodyproducts.com
Contact Daniel. Go to his link and check out the floors on his Cuda.
Todd
OMS
NYC
