Author Topic: I thought I could get by with 92 octane  (Read 3686 times)
Offline Bluemonster71RT
Re: I thought I could get by with 92 octane
« Reply #15 on: May 18, 2010 - 12:55:54 PM »
I don't like this story. Myself my wife and a few friends are gonna have are cars finished soon but were started prior to a cut in the octane that you could buy at the pump.
We have one gas station near me that sells Cam 2 @$9.99 a gal. :crying:. Other than that it's 93.  My friend 69 Cutlass that will be on the road shortly. His engine was 11:1 but has since put on alum. heads. Story is that it would effectively drop the ratio down a point? If not or it happens to ping anyway, What octane do you average using a 50/50 mix of 104/89 or 93.  Good enough or no?
1971 Challenger RT 383 4spd
Offline duncz
« Reply #16 on: May 19, 2010 - 06:36:35 PM »
Hey Al, couldn't you do a 50/50 mix with the 110 and 92 to get 101? At least your supply of 110 will be stretched out from mixing and last longer...
« Reply #17 on: May 19, 2010 - 06:57:23 PM »
I just today did 5 gal 110 and 10 of 92 and it helped a bunch but still had a little clatter under part throttle.  I did this to start diluting the 92 and mae it a higher octane without draining the system. I actually went to the track today but was only there for about 10 minutes and left. I am having trouble with my hip and it hurt too bad to stay and be active. But as little as I use my car, Im just going to keep the octane level up for now.
« Reply #18 on: May 19, 2010 - 09:39:26 PM »
Sounds like your close Al? If you have an adjustable vacume advance maybe you could tune it for the fuel you have now? Maybe try a set of plugs with a cooler heat range too?
