No tape..... But you may consider putting a heli coil in it. It isn't to bad of a job when the trans is installed. But even thread loctite isn't the answer. They have to be tq'ed in or it will not be right. One other possibility while still installed is to tap it out to a metric size the next size up. The tap would work with out the drill to, but you then have to make sure you mark that to be sure you don't mix them up.
