Author Topic: Loose Box  (Read 957 times)
Offline CHL2T
  • Handle it, man!
Loose Box
« on: May 09, 2010 - 02:33:22 PM »
I was out driving the Cuda yesterday, and noticed the steering was a little loose (manual), upon inspection this morning, I found that all three bolts were loose (again). I torqued them down last year, but apparently they want to work loose the more I drive. I don't mind having to tighten them up but I would like to not have to do it again.
Any suggestions?
locktite? Lock washers? or just keep checking them
Offline matt63
Re: Loose Box
« Reply #1 on: May 09, 2010 - 04:37:19 PM »
Are they the correct factory bolts?  The thread fits seems tighter than standard with the factory hardware.
Matt in Edmonton
'68 Valiant
Offline CHL2T
  • Handle it, man!
Re: Loose Box
« Reply #2 on: May 09, 2010 - 05:40:36 PM »
Factory bolts, near as I can tell
Re: Loose Box
« Reply #3 on: May 09, 2010 - 11:45:10 PM »
the nuts should be like a wheel nut with the tapered end into the taper on the wheel , if you have the correct nuts & they are coming loose I would use some blue locktite
Offline the_engineers
Re: Loose Box
« Reply #4 on: May 10, 2010 - 01:55:21 PM »
For the wheel...I think he's saying the steering box to K-member bolts.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Re: Loose Box
« Reply #5 on: May 10, 2010 - 03:50:10 PM »
 you are correct , I swore I saw wheel in his post
 anyway Use locktite
Offline CHL2T
  • Handle it, man!
Re: Loose Box
« Reply #6 on: May 10, 2010 - 05:14:34 PM »
Thanks guys :2thumbs:
Locktite blue it is!
Offline 'Cuda Hunter
  • Tastes Like Chicken
Re: Loose Box
« Reply #7 on: May 10, 2010 - 06:55:08 PM »
And here I thought i was going to see a picture of a loose box!   :bigsmile:
Gotta get my mind out of the gutter.  :misbehaving:
Offline CHL2T
  • Handle it, man!
Re: Loose Box
« Reply #8 on: May 11, 2010 - 08:12:43 PM »
If that was the case, I woulda posted in babe pics :smilielol:
