Author Topic: Who has the Best Prices, Complete 440 6 Pack Kit?  (Read 10201 times)
« on: May 09, 2010 - 06:21:39 PM »
Who has the best prices on a New 440 6 Pack Manifold, Carbs, Linkages, Air Cleaner Assembly, etc...The complete kit.
What is the difference between the Edelbrock and Mopar 6 pack Manifold? Same?
Thanks.
Offline 73Chally
Re: Who has the Best Prices, Complete 440 6 Pack Kit?
« Reply #1 on: May 09, 2010 - 09:32:41 PM »
Not sure about a kit price, but you will most likely do better to shop around for the components.  I saved over $400 several years ago by doing that rather than buying the cheapest kit price at the time (which I think was around $2,100).  I got the carbs and air cleaner through Summit, intake and linkage/fuel lines through Year One, and some other parts through Ebay.
Offline Katfish
  • 70 Challenger
« Reply #2 on: May 09, 2010 - 09:37:19 PM »
That's surprising, did you factor in all the seperate shipping charges?  I did a similiar exercise when I was rebuilding my front end,  no way I could beat the package deal.
« Reply #3 on: May 10, 2010 - 12:13:20 AM »
Mopar used the Eddy intake on the 69 440+6 & then cast their own iron intake for 70-71
Offline SilverChally
« Reply #4 on: May 12, 2010 - 12:57:39 PM »
I thought the early ones were cast iron then went to aluminum.
70 challenger project
68 satellite
Offline cudagirl4406pk
    • Garageartmusclecars
« Reply #5 on: May 13, 2010 - 01:08:46 AM »
There is some one www.marylandmopars.net that has a 6 pack setup for like 1000.00.
michele
« Reply #6 on: May 13, 2010 - 10:12:43 AM »
The 6 pack was used in very small #s on only the A12 lift off hood Road Runners & Supe Bees so Chrysler just used aftermarket intakes in 69 , went the 6 pack became an option on the rest of the cars Chrysler decided to cast their own intake as it became cost effective to do so with the larger # of 6 pack cars being built.
 The 340 intakes were always alum , as it was once again a small batch of special limited run cars
Offline 73Chally
« Reply #7 on: May 13, 2010 - 06:43:21 PM »
The money saved does include the extra shipping from multiple sources.  I think I lucked out, though, because at the time the carbs were dirt cheap through Summit.  I even called them to check the part numbers just to make sure they were the same ones.  I'm not sure what happened, but maybe they had a surplus at the time.  Either way, if you are not pressed for time, be patient and shop around.
