Author Topic: 71 Challenger / 73 Cuda  (Read 3580 times)
Offline JonS
« on: May 09, 2010 - 07:36:19 PM »
I have a Challenger with the following fender tag:
L25 L31 M21 R11 V78 20
GW3 U A01 G11 G33 H51
GW3 H4X9 000 223 041677
E44 D31 JH213G1B304710
Cuda
N85 R11 V6X EN2
M21 M25 M31 M88 N41 N42
FE5 U B41 C56 G36 J54
E55 D13 BS23H3B196068
The Challenger had a full interior but no broadcast sheet under the rear seat.  I didn't find it in the glove box, headliner, under the carpet, or anywhere else (the car is a shell now).
The Cuda has zero interior in it.  I haven't torn out the dash yet, but I'd imagine the broadcast sheet is gone with wherever the interior went.
I don't know anything about how to decipher the fender tag.  Can someone provide me with a resource or some information?  I'm 99% sure I have the correct number above although the fender tags are pretty rusty so I may have goofed a letter or number.
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
Re: 71 Challenger / 73 Cuda
« Reply #1 on: May 09, 2010 - 08:40:34 PM »
there could be errors but should be close
E44   318-2 Barrel
D31   Light Duty 904 Automatic Transmission TorqueFlite
JH21
3G1
B30471   Sequence Number 'B30471'
GW3
Paint Code: Brite White
H4X9
Trim Grade/Style/Color
H = High
4 = Vinyl Split Bench w/ Center Armrest
X9 = Black
000   Upper Door Frame: Full Door Panel
223   Date Built: 2 / 23 / NaN
041677   Order Number: 041677
GW3   Roof Type OR Color:  Brite White
U   Built to Specifications for USA Order
A01   Light Package
G11   Tinted Glass All
G33   Left Hand Outside Mirror - Manual / Chrome
H51   Single Air /w Heater
L25   Trunk Compartment Light
L31   Hood / Fender Mount Turn Signal
M21   Roof Drip Rail Moldings
R11   Music Master Radio AM
V78   Accent Stripes - Delete
20   Unknown At This Time
Code     Description
E55   340-4 Barrel 69-73
D13   3-Speed Manual Transmission Floor
BS23
B = Plymouth Barracuda
S = Special
23 = 2 Door Hardtop
H3B
H = 340 240HP(net) 1-4BBL 8 CYL
3 = 1973
B = Dodge Main, Hamtramck, MI, USA
196068   Sequence Number '196068'
FE5
Paint Code: Bright Red / Rally Red
U
B41   Upper Door Frame: Front Disc Brakes Some Yrs. Power
C56   Date Built: 12 / 56 / 1972
J54   Order Number: J54
M21   Roof Type OR Color:  Roof Drip Rail Moldings
M25   Wide Sill Molding
M31   Belt & Hood Molding
M88   Quater Panel Tape Treatment
N41   Duel Exhaust w/o Tips
N42   Chrome Duel Exhaust Tips
N85   Tachometer
V6X   Black Longitude Sports Stripe
EN2   End of Codes Assembly Line 2
G36   Left Hand Remote, Right Hand Manual Outside Mirror
J54   Hood Insulating Pad
72rtchallenger
what happens in the garage
stays in the garage
Alaskan_TA
« Reply #2 on: May 09, 2010 - 09:58:01 PM »
Both tags are missing a line.  ;)
Online decoders are full of errors too, for whatever that may be worth.
Offline JonS
« Reply #3 on: May 10, 2010 - 11:16:09 AM »
Alaskan,
You are correct.  I went semi-blind while trying to read the tags backwards (the front is pretty rusted):
EH2
Cuda
N85 R11 V6X EN2
FE5 A6X9 000 A19 112114
That should be better.  Where are you guys decoding this at?  I'd love to tag a stab at it myself.
Thanks again,
Jon
Offline CarelianCuda
    • http://bot.fi/3gu
1970PlymouthCuda383 FY1xE63xD32xA36xA62xB51xH51xP31xY22.........
2003TruckmastersOkenosDurangoSlt+ PRVx4.7x545RFExNV244x3.55xLSD
Alaskan_TA
« Reply #5 on: May 10, 2010 - 02:33:17 PM »
EN2
L25 L31 M21 R11 V78 26
E44 D31 JH23G1B304710
I fixed three typos where you must have had a gard time reading it. (EN2, 26 & the extra 1 in the VIN.)
Photos are good for this type of thing, it lets us see what you see. Photos of the backs of the tags can be flipped so they read right too.
Offline JonS
« Reply #6 on: May 11, 2010 - 10:11:27 AM »
This is for you guys that want to take a shot at reading these tags.  I took hi-res front and back pics.  If you need a closeup of something specific let me know and I can retake it.  The filenames are named according to what I took a picture of (Cuda Front, Cuda Back, etc etc)
Anyone that has ideas on how I would find the broadcast sheets for these cars would be appreciated.  Unfortunately, they definitely aren't in the cars.
Thanks,
Jon
Alaskan_TA
« Reply #7 on: May 11, 2010 - 12:04:21 PM »
Flipped for easy reading;
Alaskan_TA
« Reply #8 on: May 11, 2010 - 12:06:05 PM »
Offline JonS
« Reply #9 on: May 11, 2010 - 02:27:31 PM »
I don't know about "easy reading" but yeah :)
The front of both tags are pretty bad.  The backs are mostly readable.
