the brown wire powers the coil , it also comes from the start position of the ign switch , so it willl bypass the resister & give 12v to the coil while starting
the blue/ yelow wire from the electronic ign needs to be tapped into the blue wire at the oppostie end of the resister , you need to connect blact to the - coil terminal ,& leave both brown wires in place
