Author Topic: Rear Gear Oil  (Read 2958 times)
Rear Gear Oil
« on: May 10, 2010 - 08:32:30 PM »
What rear gear oil should I be using, 75-90? My manual doesn't seem to say.
8 3/4 rear.
Offline moparmaniac59
  • Drive it like ya stole it!
Re: Rear Gear Oil
« Reply #1 on: May 10, 2010 - 09:13:01 PM »
I think 75-W-90 is fine or an 80-W-90. I use 75-W-90 synthetic. Don't forget to add the limited slip additive (friction modifier) which you can find in most auto parts stores, part # 04318060ab. Good luck!! :2thumbs:
                                                 Matt B.
Matt
Re: Rear Gear Oil
« Reply #2 on: May 10, 2010 - 10:22:20 PM »
I use 80-w90 non synthetic
Re: Rear Gear Oil
« Reply #3 on: May 10, 2010 - 10:25:43 PM »
                                                 Matt B.
I didn't know you needed it with synthetic as well.
Offline Changin Gears
Re: Rear Gear Oil
« Reply #4 on: May 11, 2010 - 08:26:22 AM »
You can try it without,if it starts chattering around corners, add it.  I have found that you need it.
Offline mojavered
  • Someday!
Re: Rear Gear Oil
« Reply #5 on: May 14, 2010 - 04:19:03 PM »
How many quarts of gear oil in rear end if completely empty?  Is it a little less than 4.5 pints?
« Last Edit: May 14, 2010 - 04:21:05 PM by mojavered »
Jason
Re: Rear Gear Oil
« Reply #6 on: May 15, 2010 - 07:46:02 AM »
The service manual say 4.4 pints. That 2 litres in Canada. :bigsmile:
OxfordMotorSports
Re: Rear Gear Oil
« Reply #7 on: May 18, 2010 - 11:57:57 PM »
AMSOIL 75w90 SEVERE GEAR oil. It is the best on the market. Since cost always comes into play on these boards - it COSTS more then the rest of the field.
Todd
OMS
NYC
Offline Tonefiend
  • '70 Challenger
    • Ian A. Guitars
Re: Rear Gear Oil
« Reply #8 on: May 19, 2010 - 03:18:04 AM »
When I filled mine after replacing whole center section the manual said to fill it to the bottom of the hole.  That was alightly less than one qt.  But I had the car jacked up.  I am thinking i may need to use a pump to get some up in there.
Offline RusTy/SE
  • Just havin' fun
Re: Rear Gear Oil
« Reply #9 on: May 19, 2010 - 01:04:08 PM »
Todd
OMS
NYC
Thanks Todd (man, in my mind I keep hearing that in Gilda Radner's voice to Bill Murray on SNL :smilielol:). Fluids are one area not to be skimped on :2thumbs:
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
OxfordMotorSports
Re: Rear Gear Oil
« Reply #10 on: May 19, 2010 - 01:18:41 PM »
I build a lot of high end Dana 60' and Rockwells for my 4x4's. The AMSOIL takes a beating.
I have one truck running Dana 60's on 49's (tires) and the gears (5:13's) show no sign of wear over the last year and a half.
Todd
OMS
NYC
Re: Rear Gear Oil
« Reply #11 on: May 19, 2010 - 10:34:13 PM »
Amzoil 75-90 Severe Gear went in. Added the Amzoil synthetic friction modifier as well.
The local dealer said I probably wouldn't need it. I didn't want to go through the hassle of adding some later if it turned out that I needed to, so I paid the 6 bucks and put it in.
OxfordMotorSports
Re: Rear Gear Oil
« Reply #12 on: May 20, 2010 - 12:16:59 AM »
You did the right thing. The AMZOIL is brutal. It's been industry tested and has smoked all of the other brands. Your local dealer was correct about the friction modifier but IT CAN'T HURT. What's another 6 bucks. You might have second guessed yourself if you didn't use it. I beat the hell out of my 4x4's in the trails and in the rocks and the AMZOIL has NEVER failed me. It should do wonders for your gears on the street.
Good luck with your E ride.
Todd
Oxford Motorsports
662-259-2777
www.oxfordmotorsports@ms.metrocast.net
283 County Road 101
Oxford Miss 38655
www.newyorkcustomauto@yahoo.com
