Author Topic: Removal of the torsionbars  (Read 2538 times)
Re: Removal of the torsionbars
« Reply #15 on: May 15, 2010 - 11:31:11 AM »
Heat & penetrating oil may loosen the control arm bolt , I have had to cut through the bushings in the past to remove them , I have had to save the upper control arm typically which is not the case here having already cu tthe arm up
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
« Reply #16 on: May 15, 2010 - 01:50:58 PM »
Per, if uyou have a cutting torch just cut it out. Or send me a plane ticket and I'll cut it for you no problem!  :thumbsup:  :roflsmiley:
I will send the ticket when it's time to install the Hemi, you beeing the expert. :thumbsup:
Per
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
