Author Topic: 440, 426 Hemi Cam comparison ....  (Read 1841 times)
Offline outlawse
« on: May 12, 2010 - 09:49:59 AM »
Guys,
I have been doing allot of digging threw old Mopar books and build guides.  The question I keep coming too is this ...
If the 440 and Hemi had the same cam (284 DU 474 Lift), would the engines have been nearly identical performance wise ???  I wonder if Dodge gave the 440 a smaller cam (268/284 .450 lift) to keep the race Hemi legend alive ?
I bet that simple cam swap would have netted close to 20HP which would have taken a 440+6 engine to close to the Hemi.
Opinions ... ?
1972 Dodge Challenger
1970 446 RB: Six-Pack cam, M1 Dual plane Intake, Hooker Headers, much more...
Turbo Action 727: 3400 Stall, Manual Cheetah Valve Body - 3.91 Gears
On bench:  Performer RPM Intake, 509 114 LSA Cam, 440 Source Heads
Re: 440, 426 Hemi Cam comparison ....
« Reply #1 on: May 12, 2010 - 12:07:29 PM »
The Hemi was under-rated for insurance reasons & was handy capped with poor carbs as well , the real world #s fdor the hemi were closer to 470 in factory trim & with a cross ram or Rat roster intake & Holley carbs the power #s soared from there
Offline Marquis_Rex
  • Takes a Mopar to Catch a Mopar...
    • auto-scape
« Reply #2 on: May 21, 2010 - 06:24:09 PM »
I have access to an original Chrysler engineering Hemi resserch and development report from the 1960s.
It has the homologated power curves, Volumetric efficiency, BSFCs, ignition curves etc etc.
I haven't glanced at it for a while- but from memory:
When the engine was tested with no air cleaner, laboratory exhaust, inlet manifold heating blanked off and optimised ignition and mixture at all full load points (What alot of Detroit boys call a 'Gross power curve'- the engine attained well in excess of 480 bhp,
but with an air cleaner, inlet manifold heat, but still with labortory exhaust it was more like 477 bhp.
They had to derate it for homologation purposes:
So with a full vehicle exhaust system, an ignition system closer to production, cooling fan  and other stuff they got closer to 390 Bhp, with alternator, etc.
I was most amazed at the volumetric efficiency values they got (90% peak) and even the BSFC (brake specific fuel consumption values)- which even with a carb set up and poor cylinder to cylinder distribution due to the compromised carburetteur manifold, got a remarkable 255 g/KWH (about 0.42 lb/ hp-hr)
Most of the contemporary cars at the time homologated closer to the 2nd condition or even the first.
If you see how Hotrod magazine test- they never use an air cleaner or vehicle representative exhaust system or back pressure.
I've been involved in modern V8 engine development, homologating to SAE, EEC and DIN certification and by todays standards all of the engines from the late sixties would be very optimistic, as the intake system, a vehicle representitive exhaust system and and other anciliaries MUST BE included.
I'll see if I can dig the old report out-I aim to copy it and laminate it to stop further deterioration.
1970 Dodge Challenger 440 R/T
1995 Porsche 911 turbo (993)
1982 BMW 323i "E21"
1985 BMW M635CSi "E24"
2003 Dodge Ram 1500 4x4
1971 Jaguar XJ6 series 1
2000 Jaguar "X308" XJR
1993 Mercedes 400E
1964 MCI MC-5 coach 'RV'
