Author Topic: Comp has new SB solid rollers that require no machining?  (Read 1049 times)
Offline lemming303
  • San Antonio, TX
« on: May 13, 2010 - 08:57:28 PM »
I was looking at this month's Mopar Muscle and there was an article that mentioned using Comp's new roller lifters that require no machining. Does anyone know anything about this? I tried looking on Comp's website, but I can't find anything.
Kevin
73 Challenger Rallye - first project
Offline lemming303
  • San Antonio, TX
Re: Comp has new SB solid rollers that require no machining?
« Reply #1 on: May 17, 2010 - 01:40:57 PM »
I guess nobody has heard of them yet. If I find anything I will post it.
Kevin
Offline dodge freak 2
« Reply #2 on: May 17, 2010 - 03:34:40 PM »
Few have the money to check them out :roflsmiley:
Sounds good but I found a NOS old Crane Cam for $35 on Ebay I will run. 226 and 230 @ .030 should be great. Guess I use the money I saved from going roller on racing oil with high zinc
Offline lemming303
  • San Antonio, TX
« Reply #3 on: May 17, 2010 - 09:06:05 PM »
Well, I'm not even close to buying anything soon. I just think it's cool that they don't require machining. And since I'm gonna be building my engine from the ground up (maybe even a new block) I'm looking at all the options to get the most power possible. And if I can drop a roller cam in without machining the block, then by all means I will. :working:
Kevin
Offline moper
« Reply #4 on: May 19, 2010 - 05:22:20 PM »
Yes, comp has them. They are a design that was done with Indio Motor Machine in CA. I havent used them but there are good reports from others. Truthfully the normal rollers fit a factory type block with very minor clearancing. It's the race blocks that have all kinds of issues with them because where they need to be trimmed is close to water in the valley. I think they also have a relocate pushrod cup to help the pushrod angle.
Offline lemming303
  • San Antonio, TX
« Reply #5 on: May 19, 2010 - 05:48:20 PM »
That's good. Hopefully soon I will finally to start working on my car instead of just looking at ads in magazines! lol
Kevin
Offline mojavered
  • Someday!
« Reply #6 on: May 19, 2010 - 07:47:47 PM »
Does machining the block only refer to small blocks when running a roller cam?  I have never heard of having to machine your block to run a roller cam in a big block.
Jason
Offline djwhog
« Reply #7 on: May 19, 2010 - 08:02:40 PM »
Looks like a great cam option too! I saw this as well in the mag.
Yes a factory pre magnum 273, 318, 340 and 360s require clearancing on the block for the rollers, these new ones do not!
it would be a hot ticket for a fast ramp cam, no solid ZDP issues etc and should make great power and low wear.
« Reply #8 on: May 19, 2010 - 11:19:48 PM »
Expect the SBM has a bad pushrod angle for roller cams. The roller lifters are higher and the pushrods are shorter.
This is why the factory had those big pushrod holes in the factory cylinder heads for the roller cam engines of the late 80's-early 90's.
Offline Ck[FIN]
  • Get real - Get Mopar
    • Small car club from Finland
« Reply #9 on: May 20, 2010 - 05:41:08 AM »
I have new Comp Cams solid roller lifters. And they oil through pushrods because i use t&d rockers.
http://www.compperformancegroupstores.com/store/merchant.mvc?Screen=PROD&Store_Code=CC&Product_Code=843-16&Category_Code=SBMSRLFT
I ordered the from doug herbert, he told me that comp cams sent wrong type lifters ( they had straight tie bar). And doug ordered a new set with different type tie bar. No machining required!
