Author Topic: cuda strut rods  (Read 1291 times)
Offline rebelcuda73
cuda strut rods
« on: May 15, 2010 - 02:12:58 PM »
Does anyone know if strut rods from a 68 69 b body are the same ones used on a 74 cuda?
Re: cuda strut rods
« Reply #1 on: May 15, 2010 - 05:49:40 PM »
71-72 are the same not sure on the 69
Offline rebelcuda73
Re: cuda strut rods
« Reply #2 on: May 17, 2010 - 08:00:25 PM »
I just meassured the rods and they are 22 1/4 inches long for my 74 cuda.I still wondering about the other years from a cuda,challenger or b body.Also has anyone found an easy way to remove the old spring clips? Thanks Chris
Re: cuda strut rods
« Reply #3 on: May 17, 2010 - 09:28:37 PM »
68-72 b bodies are the same, but they all are different size diameters depending on if you had a /6,318, or a big block. Use needle nose pliers and squeeze the clip pins together, they come right out.
Offline rebelcuda73
Re: cuda strut rods
« Reply #4 on: May 18, 2010 - 04:07:13 PM »
The ones I was going to use were the original ones from the 74 cuda which has a 318 but I am installing a 440 with a hemi 4 speed.But one of them is mushroomed on the top and I would have to cut some of the threads to straighten it out.I think I would still have enough thread though.Would it make a difference using the ones from the 318 rather than a set from a big block? And as for those clips no luck they were rusted in there one of them I was able to get out , the other one is stuck in there. Thanks Chris
Re: cuda strut rods
« Reply #5 on: May 18, 2010 - 05:00:42 PM »
Hey Reb, I was wrong last night. I was refering to tq bars. The struts off of e&b from 71 72 b and 70 -74 e are the same size.  Sorry. I was having a bad time last night when I posted.  WD40 the rusted clips and use a punch to drive them out. They will come. Take a grinder and round off the mushroom on the end of the threads to a taper, then install the nut. :2thumbs:
Offline rebelcuda73
Re: cuda strut rods
« Reply #6 on: May 19, 2010 - 10:03:05 AM »
Thankyou for the info.I'll try what you said that should solve the problem.This way I should beable to start building the front end this weekend!! Thanks Chris
