Author Topic: Need help ! Clutch switch for 70 Cuda  (Read 2437 times)
Offline sportony
« on: May 15, 2010 - 07:18:54 PM »
Delco-Remy Clutch switch (70 cuda 440 4 speed).  Clutch switch that connects to the clutch pedal, so the car will start as the clutch is engaged.  Part #  2947858.  (Not even sure if this part is stock or not).
The spade terminal broke off flush with the back of the switch, so I can't seem to even solder the wire back to it.  Any ideas as to where I might find one of these ?
Re: Need help ! Clutch switch for 70 Cuda
« Reply #1 on: May 15, 2010 - 10:37:14 PM »
Very difficult to find & expensive to buy but I bet Slotts can fix it for you
Offline ShelbyDogg
« Reply #2 on: May 17, 2010 - 10:01:48 PM »
I would scrape whatever is left with a razor blade or x-acto knife to get it as clean as possible, then try the solder deal again using a freshly stripped and tinned wire. Once you get it to stay, wire tie it to the switch or glue it down so it doesn't move everytime you unplug it.
Offline PlumCrazyRTSE
1970 Challenger R/T SE, 440 Six Pack, Super Track Pak, FC7 Plum Crazy Purple
1970 Challenger R/T SE, 440 Six Pack, Super Track Pak, FE5 Bright Red
Offline vinb
« Reply #4 on: May 18, 2010 - 06:39:45 PM »
Nice switch assembly , but for $360.00, I would put a push button switch under the dash if your worrying about starting it in gear..
I mounted one on my Cuda for $8.00. I found an original used but good condition one at a sway meet later for $35.00.
Offline sportony
« Reply #5 on: May 19, 2010 - 01:34:07 AM »
OK.  Well, I did manage to get it started by just grounding the green wire to a dash bolt.  It isn't exactly original, but at least it starts now......
Guess I'll wory about coming up with the $$$ for a new or used one later.  Man, I can't believe those things are that expensive......  I do enjoy being different, but at that cost ? That's exactly why all my chevy loving friends can't understand why I drive a mopar.
Anyways, thanks for the tips and advice guys.
« Reply #6 on: May 19, 2010 - 11:33:33 AM »
catch up with member Slotts...Yes He Can...
http://www.cuda-challenger.com/cc/index.php?topic=64880.0
